Results 1 to 15 of 27
Thread: Drop in Water Pressure?
Hybrid View
    DIY Junior Member bperillo's Avatar
    Sep 2010
    New Jersey
    Default Drop in Water Pressure?
    Hi all,
    I am new to the forum. Over the last couple of weeks, I am noticing a dramatic decrease in my water pressure when another source is used. If someone turns on a faucet or flushes the toilet while the shower is running, I get a dramatic decrease in the flow. It slows to almost a trickle. This will last for several minutes even after the other source is turned off.
    This same pressure happens to the sinks. If the dishwasher is on, the kitchen sink pressure goes.
    This is a new development and I am not sure what it could be. Can anyone help with some suggestions?
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by bperillo View Post
    Are you on a well?
    Is there a recall on your water heater for diptube problems?
    Copper pipes or iron?
    The most likely problem, unless it is an old, old house with galvanized steel piping, is that you have a pressure reducing valve on your incoming line and it is failing.
    Aug 2008
    MD
    And the PRV service life seems to depend on the "cavitation index"; if you have one how old is it?
    http://www.google.com/images?client=...w=1474&bih=805
    Sep 2010
    New Jersey
    Thanks, all.
    House was built in 1986. Copper pipes. No well.
    Where would I find that PRV? How do I tell if it needs to be replaced?
    IF you have a PRV, it is likely near where the water comes into the house. Many companies make them, but they all look similar. You might check www.watts.com for an example.
  1. Hot water pressure drop in one section of house
    By Singularety in forum Shower & bathtub Forum & Blog
    Last Post: 02-24-2011, 04:36 PM
  2. Pressure drop
    By smithwd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-21-2010, 08:28 AM
  3. Water pressure drop
    By kevin schuhl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2009, 01:52 PM
  4. Water Pressure Drop
    By Siegfried in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-03-2007, 06:45 AM
  5. Why Would Water Pressure Drop?
    By nipandgab in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-24-2006, 08:10 AM
