Results 1 to 9 of 9
Thread: Where to find 1" Pex manifold?
    DIY Member benze's Avatar
    Aug 2010
    Montreal, Canada
    Default Where to find 1" Pex manifold?
    Hi,
    Does anyone know where I can find a 1" inlet, 3/4" outlet Pex manifold? I decided to run 1" Pex-C instead of 3/4" Wirsbo, and I'm looking for a mini-manifold from which I can run a handful of 3/4" lines to fixtures and risers.
    I've looked at the Watts site, and don't see any there, nor is there anything on PexSupply which I figured would have a good variety.
    Does anyone know if these exist and who makes them?
    Eric
    DIY Junior Member seavlad's Avatar
    Nov 2010
    Seattle, WA
    Default 1" inlet 3/4" outlet manifold?
    Did you find a solution? I'm looking to use a 1" inlet to 3/4" outlet manifold at the start of a trunk/branch design. I'm in the middle of a multiple phase remodel and only need to supply water to the kitchen and one bathroom. This manifold with valves would let me manage that easily and then have room for expansion.
    Dec 2009
    northfork, california
    Try the Sioux website....
    Nov 2010
    Seattle, WA
    Already did and called them as well... only product they have with 3/4 outlets are all sweat connections, really doesn't help me with PEX. Also tried Zurn with no luck and searched the internet.
    You could sweat on copper to pex adapters to the manifold...may be your only choice.
    Dec 2009
    It only takes an hour to build your own manifold and you can set the spacing and direction of the outlets and valves.
    Nov 2010
    Maine
    Uponor shows them in their catalog but I've never seen one on anybody's shelf. Better for expansion would be a 1" with 1/2" outlets and a flow through. Just cap the end of the 1" for now
    I built mine. I have 1" copper and ran 1/2" pex. Couldn't find what I wanted. If you make it yourself it can be just how you want it.
    Default manifold
    A manifold like that would be counterproductive. The idea for a manifold is to allow you to run multiple smaller lines to the various fixtures, NOT 3/4".
  1. Where to find 48"x48" double threshold acrylic shower base??
    By wrenchguy in forum Shower & bathtub Forum & Blog
    Last Post: 05-24-2010, 07:30 PM
  2. PEX Homerun manifold - use 1/2" or 3/8"?
    By pit monster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-18-2010, 04:04 PM
  3. Can I upsize from 3/4" incoming to 1" on a manifold?
    By jmk823 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2010, 12:06 PM
  4. help me find a tub for a 68" space
    By hammerhead in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2006, 03:49 PM
  5. where to find an external 8" bath faucet
    By comrade in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-23-2005, 08:50 AM
