Results 1 to 2 of 2
Thread: Remodeling bathroom.. Running drain pipes
    DIY Junior Member firemanpipes's Avatar
    Jun 2010
    palm beach county
    Default Remodeling bathroom.. Running drain pipes
    I'm remodeling my bathroom.... The bathroom has been remodeled before, and they added a 2nd toilet and a shower to the drain line in the bathroom... Now I don't want the 2nd toilet and the shower.... is it okay for me to simply put a pvc cap on each of the pvc pipes that i wish to not use anymore... Or do i need to chip all the floor out and rerun the drain line to pick up just what i wish to use?...
    Journeyman/Inspector Inspektor Ludwig's Avatar
    May 2006
    In the good ol' UPC
    If the pipes are in the walls, I see no reason why you couldn't use a permanent cap for the vents. As for the shower and toilet, when I have folks that want to remove plumbing in a slab I'll have them "dynamite" it. Wad up some newspaper and shove it down the drain, make sure it's snug and that you've pushed the newpaper wad at least 3-4" down into the pipe, fill with grout and smooth over. You can do the same for the vents if you find you don't want any piping sticking up out of the floor. Easy as pie!
  1. Remodeling a bathroom
    By Hetherr in forum Toilet Forum discussions
    Last Post: 06-22-2010, 02:35 PM
  2. Remodeling bathroom...will this drain setup work?
    By pghsebring in forum Remodel Forum & Blog
    Last Post: 10-04-2009, 04:50 PM
  3. Remodeling my bathroom
    By omahan in forum Plumbing Forum Discussion & Blog
    Last Post: 03-22-2009, 07:48 AM
  4. Remodeling Bathroom
    By Grisha in forum Plumbing Forum Discussion & Blog
    Last Post: 11-09-2006, 08:07 AM
  5. basement bathroom vent/drain pipes
    By mudrock43 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-09-2006, 11:34 AM
