Going from a submersible to a jet pump is like jumping from the frying pan into the fire. You will have lots more problems with a jet pump than a sub. Just need to figure out why you are having problems in the first place. How are you controlling the pump? Pressure tank and pressure switch? Pump start relay? Manually controlled? And what is the cause of failure of the subs?
