Results 1 to 10 of 10
Thread: Galvanized Steel Duct for Dryer Ducting
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default Galvanized Steel Duct for Dryer Ducting
    Any downsides to using galvanized steel ducting for Dryer Ducting ?
    I like the heavier gauge of the product, and the fact that it comes in longer runs.
    My dryer run is not the most ideal with 2 90 degree bends...it is what is is, but I'm inclined to do the run in the galvanized steel duct material vs the thinner aluminum stock.
    Whaddya guys think
    Jul 2007
    USA
    I used it for that reason too. I doubt it will be as resistant to corrosion as aluminium but hey, it's galvanized.
    And so are the fasterners on my deck.
    Outside in the rain.
    Remember to tape the joints and not use screws.
    Jun 2006
    No tape for me. Mastic all the way....
    well, the common round pipe also comes in 10' lengths if you know where to shop.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by chefwong View Post
    Any downsides to using galvanized steel ducting. . .vs. . .aluminum. . .
    Ask and ye shall receive. . .
    http://www.pipingnews.com/airduct.htm
    [except when you get an error message].
    Try this
    http://www.freecalc.com/ductfram.htm
    Also you have to consider that flow velocity is what carries the lint out of the pipe and the larger the pipe/duct the lower the velocity so there will be a faster buildup in the larger duct.
    Jun 2006
    I've yet to find a good trades shop on the plumbing /mechanical side....that was fair to a non trades person......I've got a GREAT electrical supply shop.
    I ended up doing the duct run in galvanized 4" round, used mastic as well as rubber buytl (mastic) foil tape. Applied mastic on the *locking seams* as well. It's as air tight as it gets......
    On to the next project, which I always despise - painting.
    The new BM Aura paint is different...you don't cut with a wet edge. It's like r********* how to paint again.
    Jul 2007
    USA
    My supply house does plumbing, lumber, electrical, landscaping and more....
    Jun 2006
    Heh. There's a great one the further I get out east but we're talking a 2.5 hrs drive...
    Unfortunately I survive by using the local boxes but things like paintbrushes, recpetacles, etc I go to the supply shop since that stuff is not *watered down*.
    I like buying framing wood at the boxes as I go there early, pick nice straight ones, etc....
    quote; I've yet to find a good trades shop on the plumbing /mechanical side....that was fair to a non trades person
    And WHY should they be "fair" to a non-trades person? If I had a supply house which was "fair to a nontrades person", I would stop patronizing them, because they would be making it impossible for me to make a living, if the customer could buy things at my cost, so that it would be difficult to add a profit to them. YOU, as a customer, can either buy it at retail from Home Depot or similar, or have me furnish it to you at about the same price.
  1. Sealaing material around a dryer duct
    By dabiz7 in forum Remodel Forum & Blog
    Last Post: 07-01-2010, 04:35 AM
  2. Dryer Duct
    By chefwong in forum Remodel Forum & Blog
    Last Post: 05-19-2010, 12:19 PM
  3. Dryer vent/ducting
    By DIY in forum Remodel Forum & Blog
    Last Post: 03-02-2010, 10:50 AM
  4. Cast iron vs galvanized steel.
    By duffers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2007, 01:18 PM
  5. Proper Dryer Duct Materail
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-08-2007, 05:20 PM
