Results 1 to 5 of 5
Thread: replacing Moen bath/shower trim
    DIY Junior Member CentralTXPreacher's Avatar
    Dec 2009
    Central Texas
    Default replacing Moen bath/shower trim
    First of all forgive me if I am not using the correct terminology when dealing with this. I'm a preacher and not a plumber!
    I am looking to replace the Moen bath/shower trim I now have (showerhead, arm, flange, escutcheon, handle and tub spout). We want to change everything to brushed nickel. I have a standard valve and only chrome comes in the standard valve. I was told I needed to get the moentrol and an adapter that would "retrofit" the moentrol to the standard adapter.
    Has anyone done this and did it work okay? Also did you have to get the valve with the trim. Seems like a waste to get the valve when it isn't going to be used. Due to cost I don't want to replace the valve.
    Hopefully this all made sense.
    Thanks in advance for your help.
    CentralTxPreacher
    The cost of the valve is often small compared to the trim! I recently replaced my mother's tub/shower fixture. The rough-in valve was about $40, the trim was $160. This was a Delta (they also have a very wide range of prices and styles). On Delta, at least the version I bought, the cartridge comes with the trim. From a practical viewpoint, though, a new valve body means possibly a plumber, so yes, it does cost a lot to change out verses just changing the trim.
    If you can identify the valve you actually have, Moen can help you figure out what will fit. A picture of the valve and trim could help those here. Depending on exactly what you have, you may or may not be able to just replace the trim - they have more than one valve, and the trims are generally not interchangeable between dissimilar models and definately not between brands.
    Moen 145058 lets you use the new Posi-Temp trims. You don't need to buy the valve.
    Dec 2009
    Central Texas
    Terry,
    Thanks again for your help.
    CentralTxPreacher
    Moentrol and Dialcet, use the same trim. The difference between your faucet and a new one, however could be HOW the two holes are arranged. The older ones have them both at the bottom, while the new ones have them diagonal from each other. There is an adapter, however, that lets you use the new trim with the old valve.
  1. Where do i get bath/shower trim?
    By jed1154 in forum Shower & bathtub Forum & Blog
    Last Post: 06-06-2009, 08:03 AM
  2. Moen shower trim ID
    By dx in forum Shower & bathtub Forum & Blog
    Last Post: 03-01-2009, 02:03 PM
  3. Replacing Trim and using old Moen Valve
    By jcm533 in forum Shower & bathtub Forum & Blog
    Last Post: 10-01-2008, 12:31 PM
  4. Replacing Shower Trim
    By macd in forum Shower & bathtub Forum & Blog
    Last Post: 10-29-2007, 12:21 PM
  5. replacing bath/shower fixtures
    By vleespet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-09-2006, 07:40 AM
