RainSoft AQ40T o-ring replacement (to start)
mjdamore
Hillsborough, NJ
Finally I MUST fix water softener. Symptoms lead to advice to replace 5 o-rings. Only have owners manual but no diagrams, etc. Where are the o-rings in such a unit? With a diagram, I know I can fix it.
mjdamore
Hillsborough, NJ
Pictures of AQ40T Rainsoft
Are these pictures OK?
Akpsdvan
Alaska
But the valve for your softener is of an older style that I am not sure if there are still parts for it..
While they may not have the o rings they still might be found at a place like True Valve hardware store. I found o rings to repair a bypass valve..
I do have a manual on that ,, but it is hard copy and not a pdf file...
There is one piston with what is listed as 3 O rings, that is under the two white wheels, then there is the two flappers that are just to the right of that piston.
mjdamore
Hillsborough, NJ
Thanks a lot - this is the 1st parts diagram I've ever seen for this unit. This looks very close to what I have. If this doesn't work, then I'll replace the control unit.
Akpsdvan
Alaska
The valve stayed the same while the control changed.
The scann is from a book that I got my hands on some 15 years ago while I was working for a company that is now out of business but had me start my own years ago.
