Thread: Help!! How do I connect the overflow and drain assy to my new kohler tub?
    DIY Junior Member Scott Vroom's Avatar
    Feb 2010
    Mountain View, CA
    Default Help!! How do I connect the overflow and drain assy to my new kohler tub?
    Once I set the new tub (Kohler Villager) in place I have virtually no access to the overflow and tub drain assy. How do I connect these without cutting a hole in the wet wall and accessing from the adjacent room? I must be missing something obvious?? Or, is this a near impossible task without cutting into the wall to gain access to the plumbing connections?
    Aug 2009
    South*East
    We install the waste and overflow first then drop the tub onto it. It take some very precise measuring.
    John
    johnjh has pretty well summed it up. Empahsis on VERY careful measurements.
    Is the wall in that bathroom above the tub still open? About the only thing you can access is necessary is the actual overflow tube by reaching down behind the tub...but not much!
    take your measurements, assemble the W/O in its final insalled position. Then drop the tub in for a looksee. You may have the tub in and out a couple of times to get it right.
    Feb 2010
    Mountain View, CA
    Guys, I like your idea of installing the waste and overflow first, , and then installing the tub. The problem is that we're installing a 60" 316 lb cast iron tub in a 61" alcove....not an easy task to pull and reset the tub if we need to adjust the wast/overflow alignment. I think I may have a solution: it's a left hand drain tub and the right side wall has a large closet behind it. If I cut out 2 studs and a couple sq ft of drywall I can create an opening through which I can easily slide the tub in and out of in order to make any necessary drain alignment correctons. and since the opening would be in the back of a closet, I could simply cover it with an access door for future use.
    I've installed this type of tub in the past in new construction and have had easy outside access to the plumbing through the opened wet wall. This is my first attempt at a remodel and to complicate matters the wet wall is shared with another shower (yep, back-to-back showers). And, the back wall of the tub alcove is the common townhouse wall and I just don't have the nerve to ask the neighbor if I can rip a hole in their living room wall to acces my plumbing .
    Anyways, thanks for the advice...very helpful.
  1. Help!! How do I connect the overflow and drain assy to ny new kohler tub?
    By Scott Vroom in forum Plumbing Forum Discussion & Blog
    Last Post: 09-09-2010, 12:12 PM
  2. using an overflow drain with a non-overflow sink?
    By chelsea in forum Plumbing Forum Discussion & Blog
    Last Post: 07-09-2008, 06:19 PM
  3. Kohler Archer which overflow and drain trim?
    By Rob223 in forum Shower & bathtub Forum & Blog
    Last Post: 05-29-2008, 02:28 PM
  4. Older Kohler Rialto With overflow holes
    By toolaholic in forum Toilet Forum discussions
    Last Post: 11-13-2007, 08:20 PM
  5. how to connect plastic shower drain to 2" copper drain line?
    By showerpain in forum Shower & bathtub Forum & Blog
    Last Post: 01-31-2007, 08:36 AM
