Thread: Help!! How do I connect the overflow and drain assy to ny new kohler tub?
    DIY Junior Member Scott Vroom's Avatar
    Feb 2010
    Mountain View, CA
    Default Help!! How do I connect the overflow and drain assy to ny new kohler tub?
    Once I set the new tub (Kohler Villager) in place I have virtually no access to the overflow and tub drain assy. How do I connect these without cutting a hole in the wet wall and accessing from the adjacent room? I must be missing something obvious?? Or, is this a near impossible task without cutting into the wall to gain access to the plumbing connections?
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    The drain and overflow needs to be put in place before the tub is installed. This can be a little tricky if you havn't done it before. It might take a few times putting the tub in place then pulling it out to get it perfect.
    If you do that, and everything is lined up perfectly, you only get one last chance to glue that last piece in...when you set the tub down.
  1. Kohler overflow installation question w/ pics...ASAP please!
    By zubz in forum Plumbing Forum Discussion & Blog
    Last Post: 05-14-2010, 07:13 PM
  2. using an overflow drain with a non-overflow sink?
    By chelsea in forum Plumbing Forum Discussion & Blog
    Last Post: 07-09-2008, 06:19 PM
  3. Kohler Archer which overflow and drain trim?
    By Rob223 in forum Shower & bathtub Forum & Blog
    Last Post: 05-29-2008, 02:28 PM
  4. Older Kohler Rialto With overflow holes
    By toolaholic in forum Toilet Forum discussions
    Last Post: 11-13-2007, 08:20 PM
  5. how to connect plastic shower drain to 2" copper drain line?
    By showerpain in forum Shower & bathtub Forum & Blog
    Last Post: 01-31-2007, 08:36 AM
