TubeGuru
Unretired defense industry engineer
I just replaced my 120V cooktop, and now its time to hook it up. The 50A service is fed through #8 stranded Al Type SE cable, and the cooktop has #12 stranded Cu. Its pretty clear to me from researching the topic that Al-Cu connections have to be done right, if they can't be avoided altogether.
The original connection (done in 1983) was a wire nut and de-ox grease, and there was no sign of oxidation or overheating. I'd go that route but I can't seem to find anything other than copper-to-copper wire nuts. Are those acceptable to use, even with Ox-Gard?
The other options would be ILSCO aluminum split bolt connectors or ILSCO crimp connectors, installed in a junction box. I'm leaning towards having a pro install a junction box and use crimp connectors. That seems to be the most permanent, reliable and safest method, short of pulling new copper.
I'd be interested in what the pros think.
