Thread: Slow cycling of well pump / pressure tank
    DIY Junior Member desmo's Avatar
    Sep 2010
    Catskills NY
    Default Slow cycling of well pump / pressure tank
    Hi all,
    We have a pressure tank setup with a well. The system cycles between 20# and 40#. I just noticed the system is cycling slowly with no fixtures "on" (maybe 10-15 minutes from high to low).
    I'm guessing the water is being pumped backed into the well. Do I need a check valve? The pump is a bit of a mystery to me, but it's a pounded well about 70' deep.
    Can I install a check valve in the house where the water line enters?
    Thanks much in advance for any information!
    - Mark
    Dec 2009
    northfork, california
    Pull the pipe and fix it from the bottom up.
    Check valve might buy you a bit of time to do that.
    Jan 2008
    Virginia Beach, VA
    If it's a driven well I'm guessing the check valve is somewhere between the pump and the top of the well. Replace that check valve and you should be OK.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    AAW jimtum's Avatar
    Aug 2010
    Decatur Tx
    If you don't see a check valve above ground then you may either have a hole in the pipe or the check valve, foot falve is not holding and as ballvalve said you will need to fix it from the bottom up
  1. Jet pump to Fertilizer Injector-Pump Cycling Issue
    By orchidherder in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2010, 01:50 PM
  2. Pressure tank short cycling
    By Tarheel Technician in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-28-2010, 06:07 AM
  3. Tank Pressure at Zero, Pump Short Cycling
    By woodworkergal in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-28-2009, 12:58 AM
  4. Pump cycling no pressure tank
    By themp in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-18-2008, 05:26 PM
  5. Shallow water jet pump very slow building pressure
    By arnie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-14-2006, 10:39 PM
