Results 1 to 9 of 9
Thread: Removing drain on water heater
    DIY Junior Member hungry bill's Avatar
    Jan 2011
    Texas
    Default Removing drain on water heater
    You removed the drain valve the HARD way. I can remove ANY drain valve in a matter of a few minutes WITHOUT damaging the jacket, or needing to "refoam" it. It would also be difficult to get a backhoe into the basement to remove the top, and since MOST people WOULD care about the cosmetics of the tank if I tried to remove the top, it would NOT be cost effective to do it.
    I am about to try draining a 9 year old WH that has not been touched since installation. I am going to try to replace the lower element because the ohm meter moved a tiny bit when I checked for open circuit between an element terminal and the tank. (Water gets too hot, and limit switch and/or breaker switch is thrown.) Thought I might as well try to replace the anode as well. Most of my projects only get done after I have tried at least 2 wrong solutions, so the plastic drain valve is probably going to break off. Could you tell me how to remove the drain valve without breaking it? And how do you get the anode out through the hot water outlet? Thanks.
    Jan 2008
    Hungry Bill, it would have been best had you started a new forum thread instead of posting a question on the back of someone elses.
    The anode rod is threaded into the top of the tank, it does not come out through the outlet or inlet.
    If the drain valve is plastic, breaking it is of no concern since it is junk anyway. Just have a replacement ready to install. If you are going to make a habit of draining it, install a quality 1/4 turn ball valve in it's place.
    Dec 2009
    northfork, california
    Breaking the valve is a great concern because you cannot get the pieces out of the threads without special tools or reach whats left through 2 or 3" of foam.
    Some anode rods ARE hidden in the outlet. I will post some links for you to read before starting, but by all means DO IT!
    http://www.waterheaterrescue.com/
    http://www.inspectapedia.com/plumbing/Hot_Water.htm
    A complete electric water heater isn't all that much money. Have you priced a new anode rod?
    When a heater gets to the ten year mark, it's normally more cost effective to replace, then it is to start repairing.
    Removing a plastic drain is not a big deal for a plumber, it could cause problems for a homeowner. Plumbers have ways to quickly remove them if they break off internally. That may be with a hack saw blade to cut a slice, or by using a bit of heat. Either way, plumbers remove them all the time. Whenever I add a recirc, I change the drain.
    Jan 2008
    Ballvalve, I suppose you are right if you consider an easy-out a special tool.
    In my life they are as common as a hammer.
    One can also carefully cut a 3-4 slots in the plastic with a hack-saw blade and remove the remainder in pieces.
    I've never seen an older residential water heater that had anywhere near 3 inches of foam insulation either.
    They must have some good stuff in California.
    Dec 2009
    This is a DIY that needs some warning or he will be without hot water for 2 days and end up with a 150$ plumbers bill.
    Terry, Great anode rods are available in .900 diameter [just makes it thru the hole] and stock .700's for about 13 to 25 $ Heres a link.
    At 50 or 60$, you might be right about cost inefectiveness.
    http://fierychill.com/catalogsearch/result/?q=anode
    And here is a great link that should be on everyones shortcuts: http://www.inspectapedia.com/plumbing/Hot_Water.htm
    A-Z Outs do NOT always grab a plastic drain valve to remove them and CAN expand the plastic making it tighter. I do NOT drain water heaters to replace the drain valve OR the elements, and I NEVER replace anodes on older heaters. I remove them and plug the opening.
    Dec 2009
    Exactly true, No draining for me also.
    But for 13 bucks, why not try and save the tank with an anode?
    My opinion is that by the time the anode rod has deteriorated, ANY exposed metal in the tank should already be coated by the rod, so it should have no benefit to replacing it. I have removed the anode rod in MANY water heaters, (one in particular that I see every week which I removed the rod from at least 6 years ago), and NONE of them have failed "prematurely".
  1. 2-3 month dle water heater; To drain or not to drain??
    By delta_v in forum Water Heater Forum, Tanks
    Last Post: 03-24-2010, 11:19 AM
  2. drain valve and removing water
    By v1rtu0s1ty in forum Irrigation / Sprinkler Forum
    Last Post: 07-08-2008, 11:37 PM
  3. Hot water heater drain
    By solutions in forum Plumbing Forum Discussion & Blog
    Last Post: 03-25-2008, 07:30 AM
  4. Water heater drain pan
    By Xenomorph in forum Plumbing Forum Discussion & Blog
    Last Post: 01-14-2007, 11:18 AM
  5. Removing water from P trap/drain
    By moobiker in forum Plumbing Forum Discussion & Blog
    Last Post: 08-14-2006, 05:16 PM
