Results 1 to 7 of 7
Thread: High water pressure outside; low inside house
    DIY Junior Member cepperson3's Avatar
    Sep 2010
    Charlotte, NC
    Default High water pressure outside; low inside house
    I have been searching for an answer to my unique problem and I hope someone can help. I have extremely high water pressure on the outside front hose bib (115 PSI). I've already had to replace part of the water pipe coming in from the street probably because of the high pressure. The plumber who did this could not figure out why the pressure is so high outside but so low everywhere inside. He said if I put a pressure regulator valve on that it would probably reduce the inside pressure even more. Anyone have any ideas? Thanks!
    My first thought was that your pressure regulator is defective. Your symptoms are classic for that. But you seem to indicate there isn't one. I would look for one somewhere, because otherwise you need to call in Dick Tracy!
    Jul 2007
    USA
    Is the pressure low or the flow low inside? Don't confuse the two.
    Did he measure the pressure inside as well?
    Low flow can be caused by pipes that are narrow.
    Sep 2010
    Charlotte, NC
    I don't remember if he measured the pressure inside, so I guess the flow is low.
    Sep 2010
    Charlotte, NC
    The plumber did not see a pressure regulator installed. I'm thinking of calling another plumber for a second opinion. Thanks.
    Sep 2010
    Charlotte, NC
    Quote Originally Posted by cepperson3 View Post
    The PRV may not include the hosebib. That can happen. I would trace the lines back and see if I could spot an old PRV, which may need replacement.
  1. High Water Pressure Spikes on Well with Pressure Tanks
    By RayMan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-01-2010, 12:57 AM
  2. High water pressure
    By At Sea in forum Plumbing Forum Discussion & Blog
    Last Post: 09-29-2009, 07:41 AM
  3. Spigot Leaks Inside House
    By kylerodland in forum Plumbing Forum Discussion & Blog
    Last Post: 02-03-2009, 08:56 PM
  4. Capping off old sewer pipe inside house
    By natemac in forum Plumbing Forum Discussion & Blog
    Last Post: 04-19-2008, 11:04 AM
  5. Inside water pressure surging - old school galv. well
    By Phil_the_pitcher in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-03-2007, 08:24 AM
