Results 1 to 7 of 7
Thread: New bathroom sink is off center and up from the exiting P-trap
    Plumber Wanna Be shadyones's Avatar
    Sep 2010
    Renton, WA
    Red face New bathroom sink is off center and up from the exiting P-trap
    The new vanity ended up with sink drain being 7 inches to right and top of p-trap aligned to bottom of sink drain,
    I move the p-trap to sink drain then added flexible length to join exit pipe (in wall) after rotating exit pipe so the curved end of exit pipe is now facing right.
    The new design just doesn't look right and I want to avoid the suggestion by neighbor to put three p-traps in series to form a flowing pipe assembly.
    Any ideas on a better design?
    Last edited by shadyones; 09-03-2010 at 12:50 AM. Reason: removed diagrams that didn't come through with correct spacing to be useful
    Dec 2007
    Can you post a picture...
    Your wording has me saying huh... But I would avoid flex lines myself.
    Plumber jimbo's Avatar
    We need a picture....but I assure you that since the word "flexible" is in your description, it is poorly done, and there is a better way! Please post a photo.
    Sep 2010
    Renton, WA
    I abandoned the flexible pipe idea. It just didn't look right.
    Exit in the wall is only 7 inches lower than the bottom of sink. And the the sink drain is 7 inches left of the exit in the wall. The pipe from the wall extends out 9", the same distance the sink drain is from the wall. Adding the p-trap causes a big gap that I am not able to connect to the exit pipe without creating a "S". Is it okay to drop the P-trap below the exit pipe, say 7 inches and then back up avoiding the "S"?
    We would really like a picture. If you are creating a "deep" trap, that is something that will always tend to drain slowly.
    A plumber could fix your drain problem, PROPERLY, in a matter of minutes. Do NOT use "three P traps in series", do not use a "flexible" connection, especially if it means you turn the trap on its side. and do NOT make a deep trap.
    You could likely cut the stub coming out of the wall, but there may be many simpler ways to do it...without seeing it, it's hard to tell. Note, the p-trap does not have to be straight with the trap arm...the trap could have the loop say go left, and the trap arm come out of it going right. After the trap arm, you want to limit the angles, but coming in and out of the trap, it's not as big a deal.
  1. P trap requirements for bathroom sink
    By larry528 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-17-2009, 07:31 PM
  2. 2" rough-in for Bathroom Sink P-Trap?
    By bjferri in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-25-2008, 06:31 PM
  3. Bathroom sink p trap or t trap
    By ksdad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2007, 06:36 AM
  4. Need advice on bathroom sink p-trap
    By funwithpowertools in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2007, 07:44 PM
  5. Kitchen sink trap on side or center.
    By paul roney in forum Remodel Forum & Blog
    Last Post: 12-24-2005, 10:52 AM
