Thread: can you solder copper and brass
    Default can you solder copper and brass
    Hi,
    can you guys tell or spossible to solder copper with brass with torch (led)?
    thank you
    Plumbing Contractor srdenny's Avatar
    SF Peninsula
    Short answer-Yes!
    Brass-an alloy consisting essentially of copper and zinc in variable proportions.
    Many solder fittings, especially for DWV are available in brass. Because brass and copper have different heating characteristics (brass takes longer to reach a particular temperature), care should be taken in making sure that no holidays are apparent in the solder flow.
    If you're soldering a brass valve to copper pipe, open the valve first. If using propane (most likely) it will take a bit longer to get the brass hot enough than if using Mapp gas. As stated, brass and copper will solder nicely.
