Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: turn furnace into a fan for summer?!?
    DIY Junior Member rbico's Avatar
    Jan 2010
    seattle
    Default turn furnace into a fan for summer?!?
    I have a furnace in my basement where it is cool. My upstairs gets really hot in the summer. I heard a DIY guru on the radio say that some furnaces offer a "fan-only" option so that the furnace can blow cool air from a lower part of the house up through the vents. I called the company that installed mine bu they said it would be $150 to install a switch. The guy I talked to said he has that option on his house and it works great.
    Keeping that in mind, last year - having nothing to do with the above - a little 6" rubber hose wore out on my furnace and there was a safety mechanism that prevented the heater/flames from going on but the fan kept going blowing cool air through the house. It took a few days for me to figure it out what the problem was - I just bought a rubber hose from an auto store and it works fine now. My thought is that I could just remove that rubber hose which would shut off the heat/flames but allow the blower to blow. Would that be safe? Or is there any other advice. $150 would normally not be a lot, but times are tight for everyone.
    thanks
    DIY Junior Member DeweyBeach's Avatar
    Dec 2008
    District of Columbia
    Does your existing thermostat have a "fan only" position (i.e., system "off" but fan "on")? If so, I'd just use that. If it doesn't have that option, I'd pull the thermostat from the wall and see which wires it has hooked to it -- my thinking is that if your furnace will run in fan only position but your thermostat can't, you may be able just to change the thermostat and achieve what you're trying to achieve. If all that fails, you can probably wire in a switch to apply 24 volts AC (which is normally operating circuit control voltage) to make your furnace fan run on its own. And if THAT won't work, you can always flip off the gas pilot light on your furnace during the warmer months and then do whatever's needed to make your furnace fan cut on.
    Basically what you're doing is a form of geothermal cooling -- the basement concrete slab is always going to be cold, and moving the warmer air around the house and getting it closer to the slab so the slab can absorb some of the heat (or, put differently, moving the air the slab has already cooled to the warmer parts of the house) is going to make things feel more comfortable.
    I'll second looking at the thermostat wiring. IF you have the manual for your furnace, look at that. Often, they wimp out and only run two wires to the thermostat, where the furnace has options for more. If the furnace is wired to control the fan separately, then it's easy, but is even easier if you have it already wired to the thermostat.
    Keep in mind that just because the basement is cooler, doesn't mean that running the fan will bring that cooler aire upstairs...you need to have a cold air return down there to get that cold air to the furnace to then blow around. If the downstairs only has exhausts, and no returns, you'll only be moving the hot air upstairs around.
    If the furnace has the internal wiring to run the fan separately, but it is not wired up to the thermostat, you could either run a new cable or just wire in a jumper. Parts wise, all it would take is a short piece of wire. If you wanted to put in a switch, Radio Shack or HD, or most any hardware store would have one that would work for a couple of dollars.
    If you can post the make and model, someone can probably tell you. The manual should show it. If you run a new cable, install a new thermostat that has the switch to control the fan separately.
    But, if you don't have cold air returns in the basement, without adding some, none of this will do much of anything.
    Jan 2010
    seattle
    thanks for the replies. The guy I talked yo mentioned the thermostat,asking if it was a 2-wire or a 3-wire. I replaced the thermostat a few years ago and I think it is only 2-wire, but it certainly doesn't have a fan-only option.
    I am not sure about the return. I think it pulls air from the floor the furnace is on, but I am nit sure. I guess I should figure that out first.
    I will look up the model number and post it here. Thanks for the help.
    Very unlikely that a furnace in the basement takes its return air from the basement. It would take combustion air locally, but not return. You need to check that out.
    Dec 2008
    I'd think that would depend if it's a finished basement or not. If the house was built with any thought at all of anyone spending time down there, then it's possible there's a return duct on that level.
    Dec 2008
    In my home, whoever wired the thermostat snipped off the unused wires, but in the furnace, they left the unused wires their original length after they stripped back the wire jacket and then wrapped the unused wires around the jacket. I found that the thermostat wires were not tightly stapled to the studs inside the wall, so I was able to grab the wires with vice grips, tug gently, and expose a couple more inches of usable wire when I needed them at the thermostat end. YMMV.
    DIY Senior Member Hube's Avatar
    Ontario
    one easy way to circulate the cool air from the basement(especially if there are no returns in the basement) is to simply remove the blower door of the furnace, install a makeshift filter over this opening, and run the blower by using the T stat setting (fan "on").
    Note; this method only to be used for circulating cooler air from the basement.....not during the heating season. When its time for the heating season make sure you put the blower door back on and re-set the t stat to fan "auto"
    Dec 2008
    Quote Originally Posted by Hube View Post
    To do this, you may have to bypass the door switch which isn't the best idea in the world. And that switch is there for a good reason -- if the door isn't closed properly when the burners are on, you can vent carbon monoxide in the house, which can definitely kill you.
    Ontario
    Quote Originally Posted by DeweyBeach View Post
    That is why I mentioned not to use this method in the heating season.
    note; there are many furnaces out there that the lower blower door can be removed with no problem being created to the rest of the system.
    Turn the gas control valve OFF, so the burner cannot start no matter what else happens. Normally, a furnace blower motor will NOT run until the fan switch detects a minimum temperature, (which would be much hotter than the temperature in the house). Most thermostats do not have a "fan on/manual" setting unless it is a heating/cooling installation.
    Electrical Contractor Bobelectric's Avatar
    Feb 2009
    Eighty Four,Pa. 15330
    Have someone change t-stat.
    without sufficient wires, and the proper circuitry/controls in the furnace, that would do NOTHING.
    In the Trades Wally Hays's Avatar
    Nov 2009
    Spend the 150 and get it wired properly otherwise using it will be a PITA. Beyond that, you can cut a return grill into the basement ductwork with a damper so you can shut it off in the winter.
    Perception is 3/4 of reality
    DIY Junior Member Denver Dave's Avatar
    Jun 2012
    Denver, CO
    I'm using the furnace fan approach occasionally this summer. There isn't a fan wire for the thermostat, but I have my pilot light turned off for the summer and the furnace has a push pull switch on the furnace where pushing the switch in, turns on the fan. The temperature of the floor in the basement can be 10 degrees cooler than the main floor in the house. To make sure the air is pulled from the basement rather than returned from the main floor, I took the front panel off the furnace, but left the filter in place on the return vents, thinking the air will take the path of least resistance, from the basement - the flowing air is cool as measured by a infra-red non contact thermometer. I wouldn't recommend leaving the furnace open even with no heat if you have small kids or pets - they might get caught in the pulley, although a screen might work.
    Other things we have done are installed solar screens on the south and east facing windows, open the house up to cool off at night and close the house up when hot outside. So far, we haven't had to run our swamp cooler, even with 104 degrees yesterday in Denver. Although I was thinking about turning the swamp cooler on yesterday, until I remembered to turn on the furnace fan for a few hours in the late afternoon. I'm in a competition on www.NegawattChallenge.org and we've really been trying to reduce our electric usage.
    Thanks for the post.
  1. Where are you going to spend your vacation? I love summer time!
    By Karoline in forum Health and Wellness Forum
    Last Post: 02-17-2011, 07:25 AM
  2. Hot (water)time in the summer
    By dhla in forum Plumbing Forum Discussion & Blog
    Last Post: 07-07-2010, 11:32 AM
  3. Winter - Summer Hook Up
    By jwilson in forum Plumbing Forum Discussion & Blog
    Last Post: 05-13-2009, 09:32 AM
  4. Outdoor Faucet Alternatives for Summer Use
    By lc1983 in forum Plumbing Forum Discussion & Blog
    Last Post: 06-09-2008, 02:28 PM
  5. how far to turn sink, tub, or toilet shutoff valves to turn on water
    By ydelamater in forum Plumbing Forum Discussion & Blog
    Last Post: 11-12-2007, 06:28 PM
