Results 1 to 5 of 5
Thread: notches and holes in floor joist
    DIY Member plaza500's Avatar
    Nov 2006
    Canada
    Default notches and holes in floor joist
    hey there folks
    i thought i had a leak in my ceiling, the plaster was cracking a bit, so today i took a knife to it can cut out a section to take a peek.
    here is what i found - now there is nothing below this, it is my dining room. no support beam whatsoever and the nearest wall is probably 3', 4' and 6' away in either direction.
    the beam has three holers drilled in it, and notch cut out of the top.
    the beam is almost 6.75" long, and the notch is 2.75" deep.
    do i now have a structural problem and what can be done to correct this?
    attached pics
    here is where it is
    Jun 2009
    Canada
    The notch in the top is a problem.
    Is it a 2x8, or 4x8 beam?
    Notches are never good. Holes in the middle, not so bad. A joist gets much of its strength from compressive strength on the top edge, and tensil strength on the bottom edge (sort of like an I-beam or truss that could be mostly hollow in the middle). Cutting it there significantly decreases it's overall strength. Cracks in the plaster show movement.
    Jun 2009
    Canada
    As far as repairing that notch, I would be tempted to pull the entire ceiling and making sure this isn't a typical practice of whoever may have worked on the home at one time.
    Jul 2007
    USA
    I make a lot of holes in joists because I like to use metallic cable.
    I try my best when placing holes.
    http://www.tileyourworld.com/constru...oringGuide.pdf
    Plumbers are the worst though when it comes to this.
  1. Offset tub drain when the floor joist is in the way.
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-02-2010, 02:09 PM
  2. UGGGH A floor joist is in my way!
    By jpb116 in forum Remodel Forum & Blog
    Last Post: 02-22-2008, 09:51 AM
  3. Floor joist in the way
    By daisyk77 in forum Shower & bathtub Forum & Blog
    Last Post: 06-09-2007, 07:22 PM
  4. Floor joist removal?
    By shov76 in forum Shower & bathtub Forum & Blog
    Last Post: 04-10-2007, 01:41 PM
  5. Shower Drain over Floor Joist
    By LarryK57 in forum Shower & bathtub Forum & Blog
    Last Post: 04-01-2005, 04:53 AM
