Results 1 to 7 of 7
Thread: piping connections to water heater
    DIY Member Steve_P's Avatar
    Oct 2008
    East TN
    Default piping connections to water heater
    I'll be replacing a gas water heater eventually and want to know the right way to install the piping to it. What I have now is copper male NPT sweat fittings threaded directly into the WH; cu tube is then sweated to the fittings at the WH. There is no dielectric union at the WH which I've read you should have for transitioning from steel to cu. It's been this way for 15 yrs and seems to be ok for whatever reason.
    So, what is the right way to do this?
    3/4 brass pipe nipple, say 4" lg; then a ball valve; then male NPT cu sweat fitting and then to tubing?
    I am not in an earthquake area (east TN) so I don't think I would need the copper flex lines, but then again they probably wouldn't be a bad idea, and they do allow a lot of room for piping misalignment.
    Many of the WH come with heat traps which also act as a dielectric union. If you didn't get corrosion on your old one, your water probably won't cause corrosion on the new one. See what the pros have to say. The addition of heat traps can save some money since they slow heat loss in the pipes when you are not using hot water. It's a good idea to insulate them as well.
    There may be almost as many ways to connect that water heater as their are plumbers doing it. In any event, if you ask 10 plumbers how to do it, you may get 10 different answers depending on how they do it in their area.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    amen hj;
    almost all water heaters come with dielectric nipples already factory installed,
    you "must" solder copper to fittings before installing on water heaters as they have
    plastic inside that will melt if you use a torch on the top of heater
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Yakima WA
    Flex copper is the preferred connector in my corner of the world. I makes the connection quite easy. We always use new flex even if the old looks OK. Some places require solid plumbing so you need to check your local code.
    And those that do not use hard copper or copper flexes will use stainless steel flexes, etc.
    Jul 2007
    USA
    ..which are not to be confused with the stainless steel braided supply lines which (although they sell them for water heaters) are quite different. And I don't like them.
  1. Water Supply Connections
    By mdk in forum Water Heater Forum, Tanks
    Last Post: 04-09-2010, 06:51 PM
  2. Water level sensor connections
    By dubman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-18-2009, 05:10 AM
  3. Removing Water Softener - capping connections
    By bobwood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2008, 03:24 PM
  4. Hot Water heater Connections
    By pilotboat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2007, 07:15 PM
  5. Water level sensor connections
    By sprinkler in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-22-2006, 12:08 PM
