Results 1 to 9 of 9
Thread: Above Ground bladder style pump won't turn off and no water pressure
Threaded View
    DIY Junior Member kimmie2000's Avatar
    Aug 2010
    Archdale, NC
    Question Above Ground bladder style pump won't turn off and no water pressure
    Hello I have been racking my brain and can't come up with a solution to this problem. Ok I got up the morning and there was no water. I checked the fuses first to see if that was my problem since I had to change them before. (Not the problem) I went outside and noticed that the pump wasn't sounding right. Only a hum. So I took the pump motor off and took it to be rebuilt. Ok problem fixed right...WRONG!!
    Now the pump won't turn off. When I first hooked it back up it cycled 30 seconds then off then on 30 seconds then off then on and won't turn off. I have a 1/2 hp jet style pump with a tank and bladder system. only whoever put this thing in didn't install a pressure gauge so I have no clue at what the pressure is. With the pump running I have a small trickle of water comming into my house but nothing else. The pressure plate box(gray box) was replaced less than a month ago. I removed the small white line from pressure plate to the top of the pump and cleaned that thinking it was clogged but no. I really don't know what else to do. Please give me another Idea. I have no money to put into this.
    Ok I was just reading the stickers on the side of the tank and it says it is a Hydro Pneumatic tank system. Does that make any difference?
  1. Pressure tank bladder
    By VA Rigger in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2009, 07:41 AM
  2. Pressure Tank Bladder
    By VA Rigger in forum Plumbing Forum Discussion & Blog
    Last Post: 10-26-2009, 03:35 PM
  3. No water, well pump won't turn on, electrical question:
    By Ddanrr in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-04-2009, 03:12 PM
  4. how far to turn sink, tub, or toilet shutoff valves to turn on water
    By ydelamater in forum Plumbing Forum Discussion & Blog
    Last Post: 11-12-2007, 06:28 PM
  5. Piston Style Water Pump w/electric motor needs help!
    By Robert in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-18-2005, 07:13 AM
