You can try and tighten the spring to increase pressure and perhaps keep it running. You can also valve down the outlet with that idea to match the flow and pressure needs of the feed lines. Or remove the switch and add a better standard pressure switch by square d. If you have a pressure tank in this setup, you could look at a csv valve too, which does automatically what tinkering with flow and pressure may accomplish.
