riddick021
Does anyone know the maximum developed length of a wet vent?
I'm in NY under the IPC. I'm having trouble trying to dry vent my tub as its a clawfoot and so there's no for me to send a vent through. There are walls nearby but not in the path the drain runs to reach the stack (the wall directly behind it is sitting on a double so I cant get a vent up into it). I've been reading up on wet venting but I'm not sure if my fixtures are spaced too far apart to do it. I have attached a layout of my bathroom with a proposed plumbing diagram. The dotted lines are wet vents, the blue dots are vents that will go straight up and the solid red is a regular drain. The shower drain is actually in the middle of the shower more or less where the solid red line starts.
