Put it all together just the way it should be without solvent. Draw a line that extends from one section to the other with pencil or marker. Put a line around the joint as well, to make sure you extend each piece into the other to the proper depth. Weld one piece at a time with solvent, lining up the marks you made for proper positioning. (Try not to erase the marks with the solvent swab)
