Results 1 to 7 of 7
Thread: What Is Causing This Problem?
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default What Is Causing This Problem?
    Hello,
    I have a stairway with a 3-way setup. A switch at the bottom and one at top. I decided to install motion sensing switches. They worked for about 6 months. Now one of the lights flickers unless I turn one of the motion switches to the off position, defeating the purpose of the switch. The other switch does not cause the light to flicker when it is in the on or auto position. What could be causing this?
    Thanks,
    Molo
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    are you using a cfl?
    Sep 2006
    cold new york
    No CFL, Incandescents.
    Gore Vidal.
    Are these motion sensing switches designed to replace a 3-way switch setup? If they are not the problem with this setup is whatever motion sensor did not trigger the light ends up being back fed with power. Electronic switches are not like regular switches and the internal components may not like being back fed . It can lead to immediate or sometimes eventual failure as you are describing.
    There are motion sensor switches available that are designed to work with CFLs. Internally these switches use relays instead of relying on electronics to do the switching. Generally these switches can be connected in a manner such as you have done with no problems because the relays don't care about back fed power.
    I have one trick you can try. If the fixture allows you to use a higher wattage bulb replace the flickering bulb with a higher wattage one.
    -rick
    Sep 2006
    cold new york
    Hi,
    Thanks for the reply. The motion-sensing switches are designed for a 3-way setup. So I'm not sure what the problem is. I could replace the bulb, but am concerned about going above the heat rating for the fixture. The bulb doesn't flicker when it is turned on by one switch, but it flickers when it is turned on by the other one. Should I still try the higher wattage bulb. Could it be the wiring?
    Thanks,
    Molo
    Gore Vidal.
    Some of the motion sensing switches rely on a trickle current through the filament...a low-wattage bulb has too high of a resistance to enable the required current for the switch to operate. Often, they list a minimum wattage that can be supported.
    Sep 2006
    cold new york
    I'll check to see if I can increase the bulb wattage.
    Gore Vidal.
  1. Ugh, AC unit has frost/ice build up. What's causing this?
    By ironspider in forum HVAC Heating & Cooling
    Last Post: 06-02-2010, 09:09 AM
  2. What is causing trickling noise?
    By juliexyz in forum Toilet Forum discussions
    Last Post: 07-10-2008, 09:14 AM
  3. What's causing the leak?
    By despec in forum Plumbing Forum Discussion & Blog
    Last Post: 09-07-2007, 02:10 PM
  4. Diverter Causing BANG in pipe.
    By duworm in forum Plumbing Forum Discussion & Blog
    Last Post: 02-05-2006, 11:26 PM
  5. Advice Needed - What could be causing this?
    By mark1210 in forum Shower & bathtub Forum & Blog
    Last Post: 09-06-2005, 12:01 PM
