Results 1 to 6 of 6
Thread: Water only getting warm.
    DIY Junior Member 48fordf-1's Avatar
    Aug 2010
    Maine
    Default Water only getting warm.
    We have finaly got the water back to the trailer after winterizing it last fall. Now we are only getting warm water from the water heater,it worked fine when we shut it down for the winter. The tank was drained when we winterized and it has been sitting for about 8 months.I dont know a lot about electric water heaters. If some one could advise me where to start I would appreciate it. I know they have heating elements & a thermostat but do not know where to start looking for the problem. I searched the forum but did not find any thing to point me in the right direction.
    Aug 2010
    Maine
    I went over to the trailer and took off the 2 covers on the side and I found a red reset button on both of units. I was able to reset the top one but the bottom one will not reset.
    I also checked the power to the elements with a multi meter and I have 120 volts going to each element. I will go over and check to see if the water is heating up in a couple of hours.
    Will update the post later.
    PS If it makes any difference it is a Kenmore water heater.
    If the lower element is out, you will only have a partial tank heated.
    The top element works first, and then the second lower element.
    If you pull the wires off, you can check the element for continuity. It should have resistance.
    If the power was applied before the tank was full (and because of trapped air, you probably would need to run a hot faucet for a bit), the element(s) not covered with water will burn out almost immediately. If you filled the tank first, hopefully after the reset, all will be well.
    Aug 2010
    Maine
    I checked both elements and I have resistance on both elements. What I did find is the lower reset button has poped off and will not reset.
    Also on the bottom element I am only getting power to one side of the element. (120 volts) The other wire for this comes from the top thermostat and is showing 0 volts there. Would this be a thermostat problem top or bottom, or maybe a shorted lower element? Don't know what to do next.
    DIY Member higgledy's Avatar
    Jan 2011
    Quote Originally Posted by 48fordf-1 View Post
    This is similar to my problem except I get pwr to both sides of the lower element and the reset button looks the same as the top. I don't think it is popped. Anyway, what was your solution? Thanks.
  1. luke warm water
    By dennislewis in forum Shower & bathtub Forum & Blog
    Last Post: 01-03-2010, 09:27 AM
  2. only warm water in shower please help!!!
    By danielspack in forum Shower & bathtub Forum & Blog
    Last Post: 09-30-2009, 11:06 AM
  3. Washing Machine -Warm Cycle is not warm
    By IhavenoideawhatI'mdoing in forum Plumbing Forum Discussion & Blog
    Last Post: 07-15-2009, 06:25 AM
  4. warm well water
    By tnlady3 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-01-2006, 10:41 AM
  5. water not warm enough
    By sueum97 in forum Shower & bathtub Forum & Blog
    Last Post: 05-31-2005, 06:37 PM
