Results 1 to 7 of 7
Thread: Can you ID this shut off valve connection type?
    DIY Junior Member NotSoHandyman's Avatar
    Aug 2010
    Philadelphia PA
    Default Can you ID this shut off valve connection type?
    My have a leaky shut off valve on my toilet. Thing is, I can't determine if the valve connection is soldered or threaded. Other important details: it has the inscriptions "CRAFT brass" and "DC" on the valve.
    It appears to be a chromed copper pipe that is tapered at the end that feeds into the valve. Is it an "all in one piece" or can I unscrew the valve from the supply line coming out of the floor? Or is the joint soldered? There is no visible evidence of solder or plumber's putty or tape (that I can see anyway).
    What can you tell me about this joint? Thank you!
    I can't answer your question for sure, it may be soldered, but here's what I'd do. Cut the pipe and replace the valve with a new 1.4 turn one, and I'd go clear to the floor so none of the copper pipe is exposed. Perhaps some of the pros will chime in on that valve connection.
    It sure looks like it is soldered on. What I'd do first is take some fine emery cloth and sand the pipe for about an inch all around to see if it really is copper and you can clean it up. If it is copper (sure looks like it), then you have a choice of either using a new solder valve, or a compression valve. Once you cut off the existing one, you can slide that corroded bell eschution off and replace it in the process. Brasscraft makes a nice chrome plated valve that would slide over the copper (it has about a 5" shaft). Unfortuneately, it isn't a 1/4-turn valve, but would look good. You can also find chrome plated sleeves to cover the pipe if you don't want to have the valve lower down, right at the (new) eschution you should slide on before a new valve is installed. You'll need a longer hose to connect back to the toilet, but those are readily available. If after sanding the pipe, you find it is banged up or pitted, you'd need to solder, as a compression fitting needs nice, smooth, clean pipe to seal to. If the pipe is really bad, you'd need to probably replace it (which could get ugly, depending on access from below).
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Yes its soldered, there's solder all over the copper pipe in fact. So what I would do is cut the pipe down a bit, use my torch to melt the solder and wipe it clean, then use a 1/4 turn compression valve and your done.
    Aug 2010
    Philadelphia PA
    Thanks for the input guys. Really appreciate your help. Once I complete the job, I'll post some awful "after" pics to demonstrate my handiness (or lack thereof). Cheers!
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    No one remembers tinning flux?
    Thats a copper pipe tinned by an old timer (bad job though)
    If Payback is so important to you, why are you not driving a Toyota Corolla?
    There's a couple of other ways to hide the old copper. Easiest way is to cut the copper low enough that the new valve will set on top of the chrome plate. You'd need a longer supply line, but that's easily done, too. Another way would be to cut the copper short, solder a female adapter to it then add a chrome pipe nipple. That would be a bit more work and expense than the first way, but the valve would be above the floor.
  1. About Pilot Valve Type...
    By Seckin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2010, 02:16 PM
  2. Question about a slip fit type plumbing connection, are they safe?
    By jonjonbear in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-17-2010, 07:11 AM
  3. Type of valve
    By Pytheas in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-27-2009, 05:43 AM
  4. Ok, pex connection type....
    By Rich H in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2008, 06:52 PM
  5. Detail question relating to sewage pit check valve and shut off valve.
    By Longwood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2007, 05:17 PM
