Results 1 to 4 of 4
Thread: Reliance 602 electric hot water heater
    DIY Junior Member jew73's Avatar
    Aug 2010
    Wisconsin
    Question Reliance 602 electric hot water heater
    bought reliance 602 50 gallon electric hot water heater 4 years ago and it stoped heating bought new upper and lower elements and new upper and lower thermostat and still no hot water power goes to all parts but no heat what else could it be?
    Did you check the power in? A bad CB, or fuse (if you don't have circuit breakers)? A bad bus bar in the panel...
    Aug 2010
    Wisconsin
    breaker is new
    A new breaker doesn't mean: it is installed properly, is the proper type for that panel, or that it works, or that it is wired properly, or that the bus bar in the panel is not bad. You need a meter or test device to check voltage.
  1. Reliance 606 Electric Hot Water heater
    By samblam in forum Water Heater Forum, Tanks
    Last Post: 01-31-2011, 09:31 AM
  2. RELIANCE 501 Water Heater specs.
    By cbirkenbach in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2007, 04:17 PM
  3. Reliance 501 water heater, pilot won't stay lit
    By jmjav in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-01-2006, 08:11 PM
  4. Pilot won't light on Reliance 501 Water Heater
    By HarmonyRose in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2005, 03:22 PM
  5. Reliance water sending electric bill sky high
    By sivright in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2005, 01:31 PM
