Results 1 to 2 of 2
Thread: Tub Drain removal ?
    DIY Junior Member fattireb's Avatar
    Aug 2010
    carmel, ny
    Default Tub Drain removal ?
    Hi All - i'm new here and have a question about removing a drain from an old tub in my basement bathroom. I want to remove it and install a new tub but can't get the drain to turn at all. I have a master extractor but it doesn't fit in that great and there is not a + on the bottom of the drain to latch into - the inside of the drain only has these 2 nubs for the extractor to grab (not working). Any advise would be great. Thanks in advance!
    Brian
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    First you could try using a pair of linesmans pliers. Just insert into the drain, open them up till they are butting against the tabs, insert a big screwdriver through the handles and turn out the strainer. If that doesn't work you can cut the strainer with a reciprocating saw in three places then pry it out. If its a cast iron tub you can just hit the tub around the strainer with a sledgehammer until it breaks (wear adaquate safety clothing, ear and eye protection.
  1. Tub drain removal for tub removal
    By FJK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-10-2010, 03:21 PM
  2. Shower drain removal
    By wmcknig in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-13-2009, 02:59 PM
  3. Problem tub drain removal
    By mrjetskey in forum Shower & bathtub Forum & Blog
    Last Post: 06-22-2008, 02:37 PM
  4. Drain removal 47 yr old bathtub
    By Sunflower47 in forum Shower & bathtub Forum & Blog
    Last Post: 05-14-2006, 07:35 AM
  5. bath drain removal
    By Howard in forum Shower & bathtub Forum & Blog
    Last Post: 10-24-2004, 08:15 PM
