69gtocv
I think I know the answer to this but I thought I'd ask anyway. Having problems finding a long sweep 90 w/low heel inlet 3x3x2 locally. I'm wanting to use this to transition from horizontal toilet drain to vertical toilet drain and use the low heel part for the toilet vent. There are plenty of the 3x2x3 regular 90's w/low heel inlet but I thought it would be better to find the one with the long sweep to better help with the "logs", right? I'm thinking this is not to code, but what about using a 3x2x3 combo wye with the vent coming off the top of the 2" straight leg of the wye? I'm guessing not because the vent opening in the wye would be starting below the upper most part of the horizontal drain. Also guessing that's why the low heel inlet was invented, to start the vent higher up in the elbow?
Thanks, Jeff
Thanks, Jeff
