Results 1 to 6 of 6
Thread: Kohler Rite-Temp Valve Disassembly
    Default Kohler Rite-Temp Valve Disassembly
    I am in the process of installing a Kohler Rite-Temp valve(model R304-K-NA) in a new shower installation. I want to disassemble the valve so I can sweat the joints near the valve. I already sweated a theaded female connector to a small length a pipe I need for the installation, and then threaded that piece onto the shower valve. I want to disassemble the valve for the next couple of joints as they are in close proximity of the valve.
    The Home Owner Guide does show exact details of the disassembly. It shows a screw as one of the first parts. I see the two screws that hold the collar on, but when I take those off, the valve doesn't come apart. Am I missing something?
    Instructions for the Kohler Rite-Temp valve here
    DIY Senior Member sulconst2's Avatar
    Jul 2005
    old bridge nj
    here is the link for installation instructions
    http://www.us.kohler.com/onlinecatalog/pdf/114811_2.pdf
    looks like after you take out the collar screws it should pull out.
    Default valve
    One small item that might make your life easier, so you don't have to come back and ask how to stop the female adapters from leaking. The copper tubing will slide right into the valve, and can be soldered there, so you do not need the adapters.
    Default Rite-Temp Valve
    Thanks guys. I got the disassembly done. As far as sweating the pipe right into the valve, how far do you have to have the pipe into the valve or are there stops? And how long do you think I have to heat up the valve before I get enopugh heat to melt the solder? Any tips would be greatly appreciated.
    Default valve
    There are stops and you only heat it until the solder flows normally.
    Guys,
    It worked out nicely. Thanks alot.
