New member and first post..
Looking for a commercial grade controller with at least 5 independent programs, more would be better. I've had no luck searching the Web for one.
Currently using a Hunter ICC with 3 modules that was installed on a new well-supplied system of 16 turf zones, 5 landscaping zones, and one Lakos sand filter flush valve. 135 turf heads with all but five using Hunter MP Rotator nozzles, the other five are PGP's.
Reason for needing 5 programs is the longer run times of the MP nozzles which require that I break up the 16 turf zones into three days of approximately 7 hours total run time each of those three days. (South Texas, sandy soil, very high temps and evaporation require 1.25-1.75 inches every 5 days.)
I don't like starting the cycles at 1:00-2:00am, too early, but heat and wind after 9:00am mandates I cease irrigation at that time. I would like to break them down into four days instead of three but I need four turf programs as well as the fifth landscaping program to do that and the ICC only supports a total of 4.
TIA..
KB
TIA..
KB
