I'm an avid DIYer, with a new project I'm planning out that I have been gathering information for. Part of said project involves transitioning from Cast Iron to PVC, 4" soil stack. The owner of the local hardware store, where I worked for a time years ago, and whose advice I usually trust, said a plain Fernco coupling (no shielding) would be fine, and is code-worthy. This seems to contradict what I've read in this forum and others and I was wondering if there are ANY unshielded couplings that would be approved for this purpose (vertical stack, cast iron from basement to PVC up to kitchen sink and second floor bathroom).
One follow-up about the shielded couplings: can the rubber part be rolled to allow the two pipes to be fit? I don't have any wiggle room to bend or move the pipes, and I can't see another way to attach a fitting.
One more follow-up: the cast iron is the hub type. I plan to cut the pipe to make the end a no-hub, and then use the fitting to go to Sched 40 PVC. Are there concerns that the pipe OD's won't be close enough? Are there some old CI pipes out there that might have odd OD's? How far from the PVC would be acceptable (1/4"? Less?)? Or do both pipes need exactly the same OD?
Thanks for any and all advice (but especially good advice),
Mike
Mike
