Results 1 to 2 of 2
Thread: Treated water smells inside, but not outside
    DIY Junior Member double-trouble's Avatar
    Mar 2010
    Snoqualmie, WA
    Default Treated water smells inside, but not outside
    I have an in-line pellet chlorinator w/ mixing tank, followed by a carbon filter. I'm treating for H2S. Water supply runs from the well, through the filters, into the house. There is also a tap for our garden hose, before it enters the house. We started out just putting 1ppm (80 gallon pressure tank, using hole #1), and the water coming from the outside tap smelled & tasted fine, but the water inside seemed to have a metallic smell & taste to it (that's the best way I can describe it). So we've gradually increased the chlorine input to now 15ppm (hole #3), and the smell & taste has reduced inside, but it's still there, even if only slightly. But now, water from the garden hose has a strong chlorine smell. Common sense is telling me that it must be the pipes feeding the house (old & mixed between copper & galvanized), am I correct in assuming this? If so, is it alright to replace the copper/steel with all pvc? If not, what else would be causing the metallic smell inside but not outside?
    AAW jimtum's Avatar
    Aug 2010
    Decatur Tx
    I trust your pressure tank is after your filtration system. Also do you know how old your carbon filter is and how big it is because it kind of sounds like the carbon is fouled and if you have iron in your water the chlorine will oxidize it and it will foul your carbon filter. You will want to use a different media to filter iron.
  1. Wolmanized (pressure-treated) Plywood inside residential areas?
    By renegade_00 in forum Remodel Forum & Blog
    Last Post: 02-28-2010, 08:55 PM
  2. Water in one toilet of the house smells - just replaced the toilet - still smells.
    By jdhanson1 in forum Plumbing Forum Discussion & Blog
    Last Post: 11-25-2009, 08:14 AM
  3. Water Smells like Sulpher
    By Doherty Plumbing in forum Plumbing Forum Discussion & Blog
    Last Post: 10-19-2009, 11:05 PM
  4. Just replaced my water line; now my water smells and tastes funny
    By fredgmeyer in forum Plumbing Forum Discussion & Blog
    Last Post: 08-28-2007, 11:21 PM
  5. Washer water smells
    By nickyg in forum Plumbing Forum Discussion & Blog
    Last Post: 05-07-2006, 10:25 AM
