Results 1 to 14 of 14
Thread: Differences between 3 Toto
    DIY Junior Member Miss Lucy's Avatar
    Aug 2010
    PA
    Default Differences between 3 Toto
    Hi,
    I am looking for a rounded bowl, 1 or 2 piece (doesn't matter), higher height (ADA?). It has to go in a teeny tiny powder room and not much space between the toilet and the wall in front of the bowl. I do not know the differences between the following and was wondering if you could tell me.
    Ultramax s854114sl vs. ms854114el. Also, I was reading your forum about the Drake II CST454CEFG .
    So the big question is, what's the differences and if the ADA is always elongated, do they make an enlongated shorter than most?
    Thanks a million for your help!
    Toto has the high round bowl Promenade, CST423 in the E or S tanks and the E and EG bowls.
    Also the Dalton CST733F
    Both of these are about 26.5" long.
    The tall Ultramax and Ultramax II, Drake II bowls are elongated, which adds 1.5" to the lenght.
    Front to back about 28" which is fairly compact.
    Aug 2010
    PA
    Terry,
    More confused now! I don't know what the E and the S tank means nor do I know the difference in the E and the EG bowls. And you're adding in 2 new series, Promonade and Dalton!
    Terry, HELP! PLEASE tell me which is the better tank and bowl, the E or the S and the E or the EG.
    And, with the Ultramaxx and Drake II, are they smaller than the standard elongated toilet of other manufacturers?
    And most importantly, tell me what to buy!! Ultramax el, Ultramax sl, Drake II, Promonade or Dalton.
    Looking over some spec sheets.... the dimension of elongagated toilets is typically 29" to 31"
    Most of the Toto toilets are much better than average. Some of your choice is to decide what style you want. Then find one that will fit in your space. Sanagloss, if available, is a good option as it helps keep the bowl cleaner (it's smoother, and stuff doesn't stick as much). The move is towards saving even more water, and the eco version of the toilet, if available, works quite well.
    Aug 2010
    PA
    May I ask one more question? I like the look of the Promenade by my husband doesn't. He wants the Drake. So the question is can I get the Drake I (CST744SL) with the sanigloss? And if not, will it make a lot of difference?
    Thanks.
    The original ADA Drake, the CST744SL does not come with Sanagloss
    The Drake II, CST454CEFG does have Sanagloss in the whites.
    It depends on the water as to how much it will help.
    I have been selling the Sanagloss CST454CEFG a bunch though.
    The letter "G" means the bowl has Sanagloss. Wiithout the G, no Sanagloss.
    Aug 2010
    PA
    Thanks so much for the reply. Am I correct in that the Drake II CST454CEFG is the 1.28 and not the 1.6? I think I want the 1.28 which is better right?
    So I either get the sanigloss or the 1.6 but not both?
    The 744 bowl and the 454 bowl are very different.
    The 744EL bowl gets a 900 gram rating, and the 454EG bowl gets a 800 gram rating.
    Any thing over 500 is very good, if not overkill.
    The 744EL bowl can take either the S tank at 1.6 gallons or the E tank at 1.28 gallons.
    The 454EG bowl only takes an E tank.
    I would go with the 454EG bowl.
    Aug 2010
    PA
    Terry,
    I messed up in my last post. What I meant to say was we want the 1.6 NOT the 1.28.
    So what we want is:
    2 piece, 1.6, G-max, round seat if possible, if not shortest elongated, ADA height
    So am I talking about the Drake CST744sl? If I am, I think that can be ordered with a rounded seat, is that correct?
    I think Terry has shared his wealth of knowledge on the subject here, and it seems you have now arrived at your " perfect" toilet.
    I might suggest that for SOME consumers, we may be overthinking this issue. Tens of thousands of toilets are installed every month. Most of them work just fine, night and day, fulfilling their intended purpose. The experts here on the forum...especially Terry on the Toto line, always share a wealth of knowledge you could NOT find ANYWHERE else! It is sort of like cell phones.....when I am in the market for a new one, I go online, in about 5 minutes find one that looks good for under $29, click, away we go. I also know people who trade in their i-whatever about every 6 months to make sure they have the latest bells and whistles!
    Back to the toilet....I have a 19 year old Mansfield Quantum pressure assist. I would not trade it for any of todays 1.28 models. If it became necessary to replace it, I would probably get a pressure assist dual flush, maybe even another Mansfield! There is no "perfect toilet" ( some of the best flushers have bowl wash problems, for example). Like any consumer, I consider ALL factors including $$$$ and availabity in making these decisions. Then I live with it! I am not in love with my new LG phone ( $14.95) but it works, and I will keep it until it croaks. Then I will go back to a Nokia or Motorola.
    Jimbo, thanks for the burst of sanity - that was like a powerful cleansing flush ;-) Like MissLucy, I've been going round in circles trying to make sense of which toilet to buy. There are so many options -- too many! -- and the wealth of information on these boards both helps narrow down the choice, and raises the stakes. I guess we're all haunted by the spectre of the perfect toilet - and the fear that it will be the one that got away.
    But in the end, even if we accidentally pick the second or third best toilet, it will do the trick. Frankly, some toilet is better than no toilet, right?
    The 1.28 Toto performs as well as the 1.6 Toto. Go with it.
    Jimbo,
    You may want to reconsider picking up a pressure assist dual flush.
    They are not made by Flushmate, but by a Chinese company called WDI Technology.
    40% of the tanks came back in the first six months I was selling them.
    The WDI EcoFlush is used in the Gerber, Mansfield and American Standard.
    WDI Technology EcoFlush
    http://www.terrylove.com/forums/show...318-a-big-Flop!
    On the other hand, the 1.1 and the 1.6 Flushmate have been holding up much better.
    The Toto 744 bowl is elongated as is the 454 bowl.
  1. Replies: 2
    Last Post: 07-03-2010, 05:33 PM
  2. Differences Between Two Am-Std and Eljer Toilets? ? ?
    By buddy.s in forum Toilet Forum discussions
    Last Post: 02-13-2010, 04:33 PM
  3. Finally! The differences between the 528 and the 528T !
    By lee_leses in forum Toilet Forum discussions
    Last Post: 01-12-2009, 02:41 PM
  4. Toto differences?
    By kdenault in forum Toilet Forum discussions
    Last Post: 08-18-2005, 04:22 PM
  5. Functional differences between Toto models?
    By Mandochop in forum Toilet Forum discussions
    Last Post: 04-05-2005, 11:31 AM
