Results 1 to 3 of 3
Thread: convert NEMA 6-20R outlet to standard 110 outlet?
Hybrid View
    DIY Junior Member cham33's Avatar
    Aug 2010
    TN
    Question convert NEMA 6-20R outlet to standard 110 outlet?
    I have a NEMA 6-20R outlet that went to an old air conditioner. The new AC uses a regular 110 outlet - 3 prong. So basically I have hot, hot, ground but I need hot, neutral, ground. What is the easiest way to go about doing this? Any help would be greatly appreciated. First time poster so go easy on me
    Plumber jimbo's Avatar
    Electrically, it would work if at the panel end you took one leg of the 240 and repurposed it to the neutral bus. You would tape both ends with white tape to identify it as a neutral. We will wait for one of our electricians to tell us if this is allowd by codes.
    Aug 2010
    TN
    Thanks! As of right now it has a hot that is white (not properly marked as hot). I inherited this home recently so it wasn't my doing. The house is old and has a fuse box, it has 2-30amp "Edison base" fuses for this circuit. I also found two 5–15R's outside under a deck, just plain old indoor rated receptacles and they were hot so I removed the fuse until I can replace them. Apparently such practices are common in this rural area of TN so I take nothing as a given.
  1. Replies: 9
    Last Post: 12-11-2012, 12:01 PM
  2. Replies: 9
    Last Post: 07-18-2008, 07:16 PM
  3. Grounding outlet
    By scta2007 in forum Electrical Forum discussion & Blog
    Last Post: 10-28-2007, 10:30 AM
  4. PRV outlet
    By charlie m in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-25-2007, 08:37 AM
  5. Natural gas outlet for BBQ
    By Guest in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-11-2006, 08:51 PM
