Results 1 to 4 of 4
Thread: water heater problems
    DIY Junior Member grizzily's Avatar
    Aug 2010
    alabama
    Question water heater problems
    installed a 40 gal. hwh soon after tp valve started to leak intermittently. checked to make sure no trash in valve. problem persisted,changed tp valve same problem. installed an expansion tank. city water pressure is static at 70psi,working at 40 psi set tank pressure at70 psi. line pressure still rises to 150 psi and leaks out of tp valve. need help in solving this problem any suggestions helpful
    Until you know WHY the pressure is going that high, and nothing you have told us indicates what the problem could be, there is no way to diagnose it. BUT, one possibility is that you already have a pressure reducing valve and it has gone bad. That would cause your symptoms even with an expansion tank, and a new T&P valve.
    Aug 2010
    alabama
    do not have pressure reducing valve. do I need one for 70 psi static pressure to house? before I changed hwh I replaced 1" galv. water pipe with 1/2" cpvc pipe. galv. pipe was almost closed up with build up. could the change in pipe size cause thew problem
    Aug 2010
    alabama
    there is no pressure reducing valve. city water supply is at 70 psi.
  1. TK-1S water heater problems
    By rogsen in forum Tankless Water Heater Forum
    Last Post: 01-27-2014, 02:10 PM
  2. Problems with NEW hot water heater...
    By ferherr in forum Water Heater Forum, Tanks
    Last Post: 11-18-2009, 04:18 AM
  3. Tankless Water Heater Problems
    By BlackDogKurt in forum Tankless Water Heater Forum
    Last Post: 09-05-2009, 03:59 PM
  4. Problems with GE Hot Water Heater
    By nottick in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2009, 02:49 PM
  5. More Water Heater Problems
    By molo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2007, 10:30 PM
