Results 1 to 6 of 6
Thread: Help needed for a water heater in the pasture?
    DIY Junior Member TJS's Avatar
    Aug 2010
    New Jersey
    Default Help needed for a water heater in the pasture?
    I have to place a heated self water in a pasture for the livestock and I am getting some conflicting information from a number of professionals.
    Heater: 120 V and 400 w
    300 ft. from service panel to the heater
    Need to know:
    1.) Size of wire?
    2.) Size of conduit?
    Thanks for your input
    TJS
    I would use #12 wires in 1/2" conduit, with metal rigid coming out of the ground to the "J" box. (No outlet and cord, because they will play with it or chew on it.)
    I just can't resist adding this video of a water heater in a pasture.
    Remember the PRV
    Water heater explosion in Kannapolis
    This news story video shows the debries from the explosion in the home.
    During their investigation, they found part of the water heater nearly 70 feet away from the building – it shot up through the roof, over a building and landed in a driveway. Debris was scattered more than 300 feet from the residence.
    You might want to run it off of a GFCI breaker. I'm guessing this is to keep the drinking water from freezing in the winter?
    I agree, #12 in 1/2 inch conduit.
    -rick
    Aug 2010
    New Jersey
    Default Thanks
    Thanks to all of you that have replied to my question.
    I know I did not mention a GFCI breaker, but I do intent on placing one in the service panel.
    My concern was that I had serveral professionals told me that I had to use #10 wire because of the distance.
    So off to the supply store for the materials and rent a back hoe.
    Thanks again,
    TJS
  1. What is needed for new water heater in new location?
    By alwaysfine in forum Water Heater Forum, Tanks
    Last Post: 12-11-2010, 06:49 AM
  2. New water heater, existing water softener, expansion tank needed?
    By dhancock in forum Plumbing Forum Discussion & Blog
    Last Post: 01-12-2009, 08:09 PM
  3. Expansion tank needed on water heater?
    By Mike16 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-10-2008, 06:01 AM
  4. Tankless Water heater problem...advice needed
    By jed1154 in forum Tankless Water Heater Forum
    Last Post: 08-27-2008, 04:23 PM
  5. Conventional Water Heater minumum space needed?
    By jdgarza_tx in forum Plumbing Forum Discussion & Blog
    Last Post: 08-31-2006, 07:32 AM
