apac
water is leaking from the top of that black thing. i highlighted in red the rod, right under which is where the water appears to be coming from. the toilet is flushing fine, but refilling takes 10minutes. wasnt like this before. it is also making a whistling type noise when refilling, but everything i read says that only happens with the old float ball design, and this toilet has a overflow valve
