Thread: HELP! Valve stuck in open position
    DIY Junior Member edouglas's Avatar
    Aug 2010
    San Antonio TX
    Default HELP! Valve stuck in open position
    I have a Hunter ICC system. It has not been activated in over two years. While trying to map out the sprinkler system, turning each station on for 3 minutes and sticking flags in the grass, the first two stations would not turn off when I set the main switch to OFF. I have unplugged the system..etc. I assume that once the valves are open and cannot be closed electronically, there is a way to close them manually. (Hopefully!)
    The only one I can currently turn them off is to turn of the water main (i.e., no water to house).
    ANY help would be GREATLY appreciated.
    DIY Junior Member Cedrus's Avatar
    Aug 2010
    Oregon
    Did you locate valve boxes in the ground? They might have a valve handle on them. Turn all the way off (not too tight). Sometimes, if the valve handle/stem is not in just the right, open position, they will not shut off. Try opening the valve 1/2 way and use the timer to activate a station. Did it go on? Probably. Turn timer to off or to another station. Did the station go off? If not, go to the valve and turn the handle down to close off. Just a bit, little by little. And wait. Did it finally go off?
    There should also be a small bleeder valve on the electric valve. It will trickle a bit when the station is on. Turn it all the way off and the valve should shut off. Could be there is dirt inside your valve.
    How is the wiring inside your timer? Any station wires loose or corroded?
    Irrigation Contractor Fireguy97's Avatar
    Mar 2010
    Kamloops, in Beautiful British Columbia
    It could also be air inside of your valves. That is what the bleeder valves are for. Getting air out of your valves when you turn them on. You also could have bad diaphrams after two years of not being in service.
    Mick
  1. Shower Diverter Handle Stuck Open
    By filthee in forum Shower & bathtub Forum & Blog
    Last Post: 02-12-2008, 04:57 PM
  2. Valve Stuck Open Question
    By Duke76 in forum Irrigation / Sprinkler Forum
    Last Post: 11-12-2007, 03:18 PM
  3. Toilet flapper gets stuck open
    By Ian Gills in forum Toilet Forum discussions
    Last Post: 08-16-2007, 05:04 PM
  4. pressure valve stuck open
    By rspainhower in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-16-2007, 06:03 AM
  5. Bathtub valve position
    By scottinTV in forum Shower & bathtub Forum & Blog
    Last Post: 06-03-2006, 05:14 PM
