Thread: Is dielectric union necessary?
    DIY Junior Member BobinChatttown's Avatar
    Aug 2010
    Chattanooga, TN
    Default Is dielectric union necessary?
    I am transitioning from galvanized to pex. The pex fitting is brass. Do I need a dielectric union, or can I just use a simple 3/4 brass pex connector?
    I have looked at numerous forums and can find no consensus on whether a dielectric fitting is necessary when transitioning to brass.
    Thanks much for help.
    To transition from galvanized to PEX, you can use either a brass or a plastic fitting.
    A dielectric is used between copper and galvanized. And not always there either. If I'm plumbing in Bellevue WA, I use a 6" brass nipple between copper and galvanized.
    Brass and steel are compatible, Otherwise we could NOT use brass valves with steel piping.
  1. Dielectric Union
    By dlarrivee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-06-2009, 03:20 PM
  2. Dielectric Union Leakage
    By Vince B in forum Water Heater Forum, Tanks
    Last Post: 11-29-2009, 02:56 PM
  3. Do I need a dielectric union for my water heater?
    By navysuit in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-18-2008, 09:54 AM
  4. Can I use teflon tape instead of a dielectric union?
    By bjrubble in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-26-2007, 07:01 PM
  5. Dielectric union V. Dielectric nipple
    By imadad2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-28-2005, 06:20 PM
