Results 1 to 6 of 6
Thread: 2nd Floor Washing Machine Puts Water Into 3rd Floor Sink
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default 2nd Floor Washing Machine Puts Water Into 3rd Floor Sink
    Hello,
    I am wondering what are the most common causes of something like this before I start to tear things apart to troubleshoot. When the second floor washing machine is running it forces water into the third floor sink drain into the sink.
    Molo
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Plumber jimbo's Avatar
    Well, the only thing I can see that would cause that is that the drain the washing machine goes into is plugged, partially. The pump in the machine is strong enough to send water up to the third floor. I am surprised that it does not overflow the drain on the second floor........is the washing machine connected to an open fitting, or is it "sealed" into a pipe??
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Maybe a backflow preventer on the second floor laundry and a blockage further down the line?
    Sep 2006
    cold new york
    Thanks for the reply,
    The washing machine goes into an open drain and is not sealed.
    Gore Vidal.
    quote: The washing machine goes into an open drain and is not sealed.
    Then it is IMPOSSIBLE for it to develop ANY pressure, much less what would be needed to force the water UP 10 feet or so to the third floor. Your analysis is faulty.
    Sep 2009
    Seattle. WA
    Pressure can very definitely be developed in drain pipes if the venting is not up to snuff. Probably the sink upstairs does not have adequate venting, so the trap contents are being
    forced into the sink by the pressure from the washer drainage.
  1. Basement Plumbing for Washing machine, Floor Drain and sink
    By novicepiper in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-14-2011, 07:27 PM
  2. Washing machine P-trap question, under floor?
    By Interlodge in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2010, 11:54 AM
  3. drain in floor next to washing machine
    By kmob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-23-2009, 09:50 AM
  4. Washing MAchine Flooded Heat/AC Floor Vent
    By optimistikchick in forum HVAC Heating & Cooling
    Last Post: 08-18-2007, 04:20 PM
  5. Washing Machine Rinse Water Backs Up in Kitchen Sink
    By Francoise in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2005, 04:22 AM
