apachebell
- Messages
- 4
- Reaction score
- 0
- Points
- 0
I moved into a house a month and a half ago.
Symptom 1: I found water leaking through the ceiling of my daughter's bedroom under the upstairs bathroom, specifically right below the toilet. I removed the toilet and found that there was some surface water damage to the subfloor right around the flange. I figured it was the wax ring. I noticed the flange was a little high, so I installed 3/8" board over the entire floor and put down new linoleum. I even sealed the base of the flange to the linoleum as best as I could with tub and tile caulk. I installed a new wax ring with the gasket inside. Two weeks went by with no problems. Then we found the leak again. The flange sits pretty well on top of the new floor. The toilet barely, and I mean barely rocks. It sits on the floor to the extent that it has made a slight indentation in the linoleum. The rocking I speak of may just be me moving the thing. It is stable. I can slide it back and forth on the floor over top of the flange and I can feel when it hits the edge of the flange (this is, of course, without the wax ring).
Symptom 2: The toilet did not flush as well after the install as before.
Symptom 3: A very small crack inside the back of the lower portion of the toilet seat. It does not go through to the back, it is just internal. At first. I thought I had found the problem, but upon further inspection, any water that gets through that crack only has one way out ... through the normal drain hole.
So, here is what I have done so far.
I have turned off the water to the toilet and we have had no leaks for a week. We have continued to use the shower and sinks. Not a drop (I have buckets). As far as the slow flush, I thought it was surely clogged. I have poured gallons upon gallons down the pipe in succession and there is no blockage. I can see down into the pipe where the shower drain comes in and there is no blockage to that point. The shower drains great, so I can only conclude that there is no blockage (far more water than from the toilet, I would say.) I am considering going with a no wax seal as my next step. I would like to avoid tearing out the ceiling to observe the leak if at all possible. The damage is not such that it has to be repaired. The water came through a crack in the drywall.
I would welcome any help. Please.....
Tim
Oh yeah, I have pictures of both the wax ring when I pulled the toilet up and the crack in the seat, if someone experienced would be kind enough to accept 2 pics via email.
Tim
