Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Kinetico flooding
    DIY Junior Member phoebe's Avatar
    Aug 2010
    UK
    Default Kinetico flooding
    Hi -
    I have a kinetico block salt softener about 12 y o. I currently have it isolated, as it recently flooded the kitchen. There is no obvious blockage in the overflow and water does drip through it, but when the machine is not isolated, water is flowing into the reserve tank at full pressure causing the water level inside to rise and rise until it floods over the top of where i put the salt in. I have tried trying to get it to manually regenerate, but it does not. The other thing that may be worth a mention is that, whilst investigating this problem, I have noticed that the open/close valves on the pipes to the machine leak when open.
    I have tried my local service engineers, but am waiting since Friday for a call back - any ideas please?
    The float assemble stops the water from flowing into the salt tank. Pull the float out of the salt tank and clean. Pulling up on the center rod should stop the water flow.
    Aug 2010
    UK
    thank you, i have tried removing and cleaning the float assembly. I replaced in the machine, and turned the water back on............. in doing so, I think i have discovered the problem. There is a split in the high pressure hose between the float assembly and the machine; could this be the reason that the machine will not manually regenerate also??? Could it be that there is not enough water pressure to get it to do so? And finally, do i need a kinetico specialist to replace it, or could a plumber do the job?
    Thank you for your assistance ;-)
    Kinetico is sometimes very fussy about who they will sell parts to, so, even if you could fix it, you may not be able to get the parts. Not sure if this is generic.
    Quote Originally Posted by phoebe View Post
    If it's the hose that is split, you can replace it. It's a standard 3/8" high density tubing. If the split is close enough to a connection, just cut out the bad part for a quick fix and replace soon.
    Aug 2010
    UK
    Thanks again - could you comment on whether the split would account for the machine not regenerating?
    Being non electric and with the serious water leak reducing water pressure, the control valve may not have enough pressure to regenerate. Fix the leak and it probably will regenerate.
    Aug 2010
    UK
    I am missing my softened water and cant afford £70+vat + parts call out fee. I can often fix things by myself ........ fingers crossed!!
    Is the split on a hard plastic line or a flexible line. 3/8", 1/4"? What is the model number. You said you use a 'block salt type" unit? How big are these blocks (-+ 1/3 stone)?
    The crack in the hose will not prevent the unit to going thru a regen, but will cause it not to draw brine which will result in hard water.
    Quote Originally Posted by Skip Wolverton View Post
    Really. How do you know that the leak isn't big enough to rob enough pressure to cause the water powered control valve to not be able to move the valving? Or, that the water flowing to the leak isn't preventing the valve from moving?
    I wonder what your incoming pressure is? If the excessive pressure caused both leaks, then a pressure suppressor/regulator may be needed. Check what maximum pressure is permitted with the softener and what is coming in your home.
    Hi -
    We're talking about a 3/8 line vs a 3/4 or even 1"inlet/outlet. There is no way for a 3/8 line to rob enough water to prevent the unit from starting a regen. If that were the case, anytime the unit was in a fill cycle, the customer would not have water flow in the home.
    Aug 2010
    UK
    THank you for your help guys - I had to give in and call an engineer and am now £150 poorer.
    The hose was split, and the fact that it was and that the vacuum was not maintained after the overflow caused the machine to not regenerate ????
    Anyway - all fixed - hopefully I will be enjoying softened water again soon.
    Thanks again
    Phoebe x
    Oh - and the water pressure in the daytime at the outside tap was 95 - he recommended that I fit a pressure control valve....... but wants a further £150..... not much chance of that then!!
    Take note that daytime pressures are usually LOWER than nighttime peak pressures. At least in the US, a regulator is required when the pressure exceeds 80#. If you do add one, you will probably also need an expansion tank (assuming you have a tank type heater, which you may not), to prevent the water pressure rising while the water heater raises the temperature and the water expands. A PRV makes the system 'closed' in that that expansion can't be passed back to the mains.
  1. Bsement flooding remidies?
    By csr0831 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-25-2010, 10:09 AM
  2. Flooding
    By Cookie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2007, 05:16 PM
  3. pop-up sprinker flooding
    By dianne in forum Irrigation / Sprinkler Forum
    Last Post: 12-31-2006, 08:38 PM
  4. Basement flooding
    By price914 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-30-2006, 09:14 AM
  5. basement flooding
    By johnnydeppsgirl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-23-2005, 11:12 AM
