Thread: had great pressure now just a trickle????
    DIY Junior Member pllckjsh's Avatar
    Aug 2010
    ohio
    Question had great pressure now just a trickle????
    hey guys quick question i just remodeled my bath at home and put in a new moen faucet. I had great pressure out of the old faucet but now i just get a trickle. It wont even know the tooth patse off a tooth brush. I have replaced to shut offs(after problem was found) and cleaned the faucet guts real good the only other thing i can think of is the cartridge that is doing this? any idea's
    Thanks Josh in ohio
    remove the aerator on the faucet and clean it out
    Like Jimbo said, the most likely culprit is debris in the aerator screen. If that's okay, do you have good water flow from the shut off valves directly? (disconnect the supply line from the faucet and run it into a bucket). If both those check out, then the faucet cartridge is all that's left.
  1. Low-yield well, is a trickle feed possible?
    By Guvner in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-13-2009, 08:30 PM
  2. I have trickle of water but its not a pressure issue?
    By Selgea in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-03-2008, 09:54 AM
  3. Pressure at tank is great, in house is low unless pump is running
    By greghughes in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-16-2008, 09:06 AM
  4. Toto Carlyle - trickle sound after flush
    By remodelingit in forum Toilet Forum discussions
    Last Post: 09-25-2007, 11:44 AM
  5. flow down to trickle. Why?
    By geniescience in forum Plumbing Forum Discussion & Blog
    Last Post: 08-06-2007, 05:55 AM
