To properly set up your unit you need to provide a water analysis that includes, at a minimum, hardness, iron, manganese, pH, and TDS.
Your water quality could have changed over 6 years or the unit may not be functioning properly. Changing the salt will not change the amount of salt used--but a malfunctioning unit can use less salt and not provide adequate softening.
