Results 1 to 5 of 5
Thread: Plastic to plastic threaded fittings... use teflon or not?
    DIY Senior Member DavidTu's Avatar
    Dec 2009
    Seattle, WA
    Default Plastic to plastic threaded fittings... use teflon or not?
    On a boat's fresh water system I had to replace a threaded hose fitting. I put on teflon tape thinking it would help seal better but no matter how tight I screwed the fittings together I still get drips. Now I am wondering if w/ plastic to plastic threaded fitting connectors, is using teflon causing the problem? (Any other ideas why it'd still leak?--it cannot be further tightened)
    Plumber jimbo's Avatar
    One to two wraps max of tape is ok. Main cause of leakage on plastic threads is overtightening. Hand tight plus one/half to one full turn...that's it. You have proabably already distorted the threads.
    quote; Hand tight plus one/half to one full turn...that's it.
    I have never seen a plastic thread NOT leak if that procedure was followed. I tighten them until they are TIGHT, regardless of how many turns it takes.
    DIY Member RinconVTR's Avatar
    Sep 2009
    Wisconsin
    Not using tape will not only allow leaks, but it can also "weld" the plastic together making disassembly almost impossible.
    This type of thread is tapered and interference...to seal between the threads, you MUST use something, either tape or a pipe dope rated for use on the plastic pipe you have. Under an ideal world, 1/2-turn after finger tight MIGHT work, but don't count on it.
  1. Connecting Plastic Fittings to Copper
    By tonyn1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-16-2007, 08:24 AM
  2. Plastic Tubing Compression Fittings
    By deuce1974 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-05-2007, 08:59 PM
  3. Teflon Tape on Plastic Threads
    By bakechad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-02-2006, 05:12 AM
  4. Threaded PVC Fittings
    By bf9ys02 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2005, 08:44 PM
  5. threaded fittings
    By oops in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-27-2005, 09:32 PM
