Results 1 to 8 of 8
Thread: pipe size /max length of run for kitchen, Canada Code
    DIY Junior Member Philbert's Avatar
    Aug 2010
    Toronto,Ontario,Canada
    Default pipe size /max length of run for kitchen, Canada Code
    hello
    I have been asked to rough in a new kitchen, it has 1 double sink and a dishwasher beside it, the soil pipe is 25 to 30 feet away, I don't want to run 3 inch all the way if it isnt needed , thanks
    Even IF 1 1/2" would be approved, there is no way I would EVER use it for anything other than a vent. I ALWAYS use 2" minimum for my drain lines.
    Aug 2010
    the problem I am having is that if I seach online for a quote from the npc I get a vague reference to some "complicated table" in the plumbing code book which I can acces online unless I pay for it or order a copy of the code book for a price of course,if ther is no restriction all the better, although I will likely use 2 inch anyways, ohhh the 25 to 30 foot run is a sloped run not a drop ifin that changes anything
    It is not a "complicated table" at least not in the books down here. Each fixture is desinated by a number which correlates to how much water is likely to go in it. The number is called "fixture units". In the UPC, a kitchen sink is 2 FU. By the simple table, the maximum # of FU on a horizontal 1½" pipe, beyond the trap arm, is ONE. So the sink needs to drain into a 2" lateral. The horizontal length ( with 1/4" per foot slope minimum) is unlimited.
    Jun 2009
    Penticton, BC
    Quote Originally Posted by Philbert View Post
    hello
    1.5" is perfectly acceptable as long as you pick up your vent within 6'.
    I usually have a 1.5" fixture drain picked up by a 2x1.5x1.5" tee.
    I haven't seen 1.5 for kitchens since the 50's in the lower 48, not Canada though.
    Here we use 2" until the vent, and then a 1.5" trap arm.
    I guess the Canadian code for kitchen plumbing is pretty weak.
    Certified Plumber Plumber1979's Avatar
    Jul 2012
    Ontario
    im a plumber here in Ontario and its just fine to use 1 1/2 on a kitchen and it 5' for the vent
    1-1/2" is fine. trap arm max is 5' (1.5m). cleanout required on fixture drain or union p-trap. cleanouts every 20' (6m).. you'll want to make sure your slope is right to keep a kitchen sink line that long, clear of grease etc.
    secondly NPC is not what you need. you need to refer to the Ontario Building Code section 7 - Plumbing
  1. Laundry drain pipe help for s-trap location. Canada
    By klrman in forum Canadian Plumbing Code Questions
    Last Post: 06-03-2010, 02:40 PM
  2. Laundry drain pipe help for s-trap location, Canada
    By klrman in forum Plumbing Forum Discussion & Blog
  3. Typical drain pipe size for IPC code?
    By Mudball in forum Plumbing Forum Discussion & Blog
    Last Post: 08-24-2009, 06:22 AM
  4. IPC Code: Main line and Venting size
    By construct30 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-05-2007, 05:21 PM
  5. Matching pump h.p. to well point size and length?
    By ron in sc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-06-2007, 05:52 AM
