Results 1 to 9 of 9
Thread: Screws in Durock...tool late?
Hybrid View
    DIY Member coopns's Avatar
    Sep 2006
    Massachusetts
    Default Screws in Durock...tool late?
    Finished the Durock with thinset at 2. Cleaned up, thought about screws. Started screwing some in at 3:45. Started to panic, got more screws and put some every six inches all over - done at 4:15 or so. (Small bathroom 32 sq. feet). Could see it was still being pulled down in spots. Before that I put some tile boxes and weights on some spots I felt were a little loose.
    Do you think that will be all right?
    The pot life of thinset varies depending on the type, how it is mixed, the humidity, and how damp the surface you apply it to. If the thinset still mushed when you screwed it down, maybe. If it were tile you were trying to adhere, absolutely not, but the goal of thinset under cbu is to fill in minor imperfections so the board is fully supported. IF that happened, you should be okay. Otherwise, you've got problems. Hard to tell without being there. No guarantees. Safer to remove and replace, but it could be fine. You'll get more and better results where you started this over at www.johnbridge.com - those guys deal with tile every day.
    DIY Member TWEAK's Avatar
    May 2009
    Bay Area CA
    As long as you have enough thinset under there to support the durock, it will be ok.
    The problem you might have on a floor, especially if using typical 1/4 inch backer board, is if the resulting durock suface may have become wavy - that is, not flat. This isn't a fatal problem, but it IS a major annoyance and will make the tile setting much harder. The problem is that you'll have a hard time with lippage (that is the term for the effect you get when one tile is at a different height from an adjoining tile, creating an annoying "lip"). I've dealt with this in the past by locating the high and low spots in the durock surface, and using a size or two larger notch size trowel in the low areas.
    If you put a long level on your floor (durock surface doesn't have to be truly and perfectly level, but it should be flat... a 4 of 6 foot level is a good way to check for "flat") and discover that you have an out-of-flat problem that's pretty severe.... say 1/4" or more.... it will be way, way easier in the long run to build up the low spots with a skim coat or two of thinset, or medium bed mortar. Or, if it's really bad, even self-leveling concrete. The tile setting will go MUCH easier if the floor is flat, especially if you're using 12" or larger tiles.
    The reason for cbu installation over plywood is so that you have a surface that is compatible with the tile, expands and contracts the same way as the tile, so it all works together. What actually happens over time (and it doesn't happen quickly), is that since the cbu (or tile if adhered directly to the wood) expand and contract at different rates, and the bond can be broken. So, if you follow the manufactuer's instructions and use an unmodified thinset, it has no elasticity to it, the bond will break and you have the cbu and tile disconnected from the subflooring. When using the specified fastener, what really happens long-term is that the tile and cbu move, and actually crush the cbu around the fastener so the cbu and tile are a floating floor, held down by the fasteners. this motion is very small, but exists. If you choose to utilize one of the approved methods of tiling directly to (two) layers of plywood, you are required to use a highly modified thinset (which has a little give to it). Use a lower-compliant thinset, or have a less than perfect installation, and you risk failure. There are organizations whose sole purpose in this is to evaluate tiling installation methods and come up with methods that work long-term, under adverse conditions. The manufacturers run their own tests. Trying to second guess all of that research with a few personal experiences is fraught with room for failure in the general use situation. Plus, except maybe in a home situation where you DIY, this failure can take years, often gets disconnected from the installation method utilized...in other words...things could fail, and you would never know why or if.
    RTFM, and follow it. You might get lucky, you might not, if you don't.
    The thinset in a cbu installation is there to fill voids, NOT to hold the panel in place. The fasteners hold the cbu in place, and a second purpose of the fasteners is to smush it into the thinset to minimize the notches (i.e., spread them out to fill in the gaps - providing the desired 100% coverage).
    May 2009
    Bay Area CA
    Jim, I am curious about what you're reading in the above posts that leads you to believe that anyone is "second guessing". OP has thinset under his CBU, has screws every 6 inches, and while he waited too long before screwing, it was still was wet enough to mush when he drove the screws. Should be fine. Skim coating the low spots in CBU to get it flat is nothing new or particularly controversial.
    The pot life of most thinsets is in the order of an hour (some are longer, some are less). Once spread out, it starts to tack up much quicker, especially when applied to wood, and the cbu (depending on the type) can be quite thirsty, too. So, after two hours under the board, you are at risk. Note, he said it pulled down in some areas, implying there were areas that didn't. This could lead to uneven coverage, which is the whole purpose of using the thinset in the first place.
  1. plumbing hand tool.. for manually striking tool with hammer and driving a cement nai
    By firemanpipes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-05-2010, 07:35 PM
  2. Late September Dogs at the Showbox August 15th 2009
    Last Post: 08-11-2009, 11:29 AM
  3. Stock up on guns and ammo before it's too late.
    By jimbo in forum Computers and Stuff
    Last Post: 04-24-2009, 06:34 AM
  4. Ceramics and Durock
    By Buster55 in forum Shower & bathtub Forum & Blog
    Last Post: 01-06-2007, 05:16 PM
  5. Cleaning off flux [better late than never]
    By Taylor in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-10-2005, 01:49 AM
