Results 1 to 4 of 4
Thread: 16 year old water heater - time to replace?
    DIY Junior Member larrymcg's Avatar
    Dec 2009
    Silicon Valley
    Question 16 year old water heater - time to replace?
    We re-piped our house with copper and got a new water heater 16 years ago. It's gas fired and has a pump with return line. I've never done anything to maintain the heater - flushing, anode replacement, etc. I mention the pump and return line because I think (but don't know) that would help keep the sediment from collecting on the bottom of the tank because the return line goes into the bottom (through the drain connection).
    Since it's 16 years old, should I just replace the entire water heater even though it's not giving me any problems?
    --Larry
    It could last another 10 years, or it could start leaking tomorrow. There is NO way for you, me, or anyone else to tell which, or when it will fail. It is up to you to decide how you want to throw the dice. I do not advocate replacing them until they start to leak, but then I do not know your situation and whether a leaking heater could cause water damage.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    If and when you do go to replace it be sure it is a Bradford White or Rheem/Rudd model
    as of 2003 their is new burner and pilot technology out that other
    water heater mfg's
    are having problems with, look at the flame guard post at the start of this section to get a ideal about what I am saying !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Yakima WA
    You are definitely on borrowed time, but as long as it is working OK and shows no leaks, there's not much reason to replace it. I would start a savings account for a new heater so when the day comes, you'll be ready. As noted previously, a Bradford White or a Rheem seem to be the best heaters. By all means avoid the Whirlpool.
  1. Culligan Mark 812 Water Conditioner - Time to replace?
    By rstier in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-06-2009, 08:09 PM
  2. To replace or not replace...hot water heater?
    By hhcibtpaun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-03-2009, 10:14 AM
  3. Nine Year Old 50 Gallon Water Heater
    By hudson in forum Water Heater Forum, Tanks
    Last Post: 04-12-2009, 05:44 PM
  4. Flushing Out 15 Year Old Water Heater
    By wraujr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-28-2008, 06:30 AM
  5. 14yr Gas Water Heater-time to replace ?
    By tototalitarian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-08-2008, 04:17 PM
