Thread: Can I use unused tankless for heating?
    DIY Junior Member john2129's Avatar
    Jul 2010
    Westborough, MA
    Default Can I use unused tankless for heating?
    I have a V-1 Burnham boiler with forced hot water heating. The tankless part has never been connected to anything. Can I plub this into my FHW system - I'll test for leaks first.
    In the trades Dana's Avatar
    Jan 2009
    What's the point of using the tankless coil for space heating rather than the boiler itself? The tankless coil's heat exchanger, is not of infinite heat-exchange capacity, but is probably enough to handle moderate space heating loads. It's output capacity will depend on the temp you run the boiler at, which may be a a higher (==lossier, lower efficiency) temp than if running the heating system directly.
    Jul 2010
    Westborough, MA
    Default Sorry, I was not clear...
    My boiler IS used for FHW space heating. Would it increase heating efficiency if I plumb the unused tankless coil into the space heating system. Thanks for your patience.
  1. sealing off unused WH drain?
    By hamlet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-30-2010, 11:45 PM
  2. Tankless vs Tank for Heating & Domestic Use
    By Canada_Dave in forum Tankless Water Heater Forum
    Last Post: 04-16-2009, 07:11 AM
  3. How to block an unused vent
    By thegallery in forum HVAC Heating & Cooling
    Last Post: 12-14-2007, 10:27 PM
  4. Radiant heating with tankless water heater
    By lionz1fan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2007, 08:56 PM
  5. Diagram-tankless shop heating?
    By tractor1971 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-25-2006, 08:50 PM
