Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: Why plumbers putty on base of toilet??
    Default Why plumbers putty on base of toilet??
    I know this may be a strange question but here it goes. Why do you put plumbers putter around the base of the toilet when you install it? I think if there was a leak around the wax ring and the plumbers putty was used it would seal in the water and cause the floor to rot around it. Without the putty the water would come out from the base of the toilet and you can then see the leak and fix it. Comments?? Thanks Stan
    That's why in some areas, the inspectors insist that you don't seal all the way around the bowl.
    Trapped water under the bowl can cause rot.
    I don't use plumbers putty either.
    It has oils that will discolor some floors.
    I prefer something like PolySeamSeal.
    Default I agree with Terry
    Terry is right. I read from books that you may want to leave behind unsealed, just in case there is water leakage down below.
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    Default grout
    I found that toilet manufacturers don't make toilet bowls that won't wobble and when you couple that with a ceramic floor that's hard to get perfectly level, you do have to shim and grout, not calk, to make the setting of the toilet solid. I prefer to come close to the color of the grout in the tile.
    Tradesman Plumber Kristi's Avatar
    Jan 2005
    Vancouver, BC
    can't get the wobble out? I loosen the bolts, jam pennies around different points that can fit them and cinch the toilet down again, works every single time... and I sometimes leave them uncaulked, sometimes the owner specifically asks for none...
    I've never put plumbers putty under there!
    Aug 2005
    Florida
    Default plumber1
    Who uses plumbers putty?
    Jan 2005
    Vancouver, BC
    I don't know, who uses plumbers putty? I might have commented on that from Stan's original post...
    Aug 2005
    Florida
    Default wobble
    Pennies are temporary unless you grout right away.
    If you want a good finished job I think you should grout and not calk, unless it's a job that gets inspected and is required.
    Default putty
    "Decades" ago plumber's putty was used to set the toilets, like the wax rings are used now. But even then the putty was not used to seal around the base of the toilet. It does not bond to the toilet and floor, nor does it harden up within any reasonable time, so it will not prevent "wiggles". It can stain the floor and will discolor over time.
    Here, the inspectors specifically look at the bottom rear of the toilet to be sure that spot was not left uncaulked.
    DIY Junior Member RBrown's Avatar
    West Virginia
    Default Putty
    My plumber used putty instead of a wax ring to set my Champion toilet. So far so good.
    Aug 2005
    Florida
    Default putty
    Putty will do in a pinch.
    But what plumber won't have wax rings on the truck?
    I think that you were short changed.
    DIY Senior Member finnegan's Avatar
    Aug 2005
    CT
    Often a bead of putty on top of the wax ring will be used to ensure a good seal. This is different from using it to set the base of the toilet.
    Smile
    Quote Originally Posted by finnegan
    BINGO!! I learn things everyday on this forum. Never thought of that... Thanks,
    Regards, Tom
    Wax is supposed stick to the bottom of the toilet. That's why they don't glaze the bottom of toilets.
    I don't really see why wax wouldn't be used, since it does such a good job of sticking to the toilet.
    Aug 2005
    Florida
    Default putty
    Putty certainly won't help and will hinder a good seal.
    I would never do that.
